05-02-2006, 09:23 PM | #1 |
Junior Member
Ac Control-how Many Vacuum Lines??
Hi Y'all
I Just Rebuilt An Ac Control Unit. I Noticed That One Unit That I Had Has 3 Connectors For The Vacuum Hoses To Connect To. The Other Unit (a Donor Unit-i Stole The Levers)has 2 Connectors For The Vacuum Lines To Connect To. My 1970 Chevy Shop Manual Shows The 2 Connector Style. Anyone Know How The 3 Connector Style Ac Control Unit Should Have The Vacuum Lines Routed?? Thanks, Mongo1957 |
05-02-2006, 11:00 PM | #2 |
Re: Ac Control-how Many Vacuum Lines??
you can use either, but on the one with three ports will require that one be blocked off. Correct would be the one with two ports.
05-02-2006, 11:10 PM | #3 |
Junior Member
Thanks Stope4-i'll Block Off The Third Port
05-03-2006, 05:18 AM | #4 |
Here is the vacuum diagram for the three port vacuum switch.
Jim |
05-03-2006, 10:15 PM | #5 |
Jim, what is the specific year and vehicle for the diagram you show.
05-09-2006, 08:16 AM | #6 |
The schematic was in my Assembly Manual for the 67-72 trucks and there was no mention of the year. The (5) trucks, (70-72) that we have with AC have the two port control so my assumption is that the three port controls are from the 67-69 years. It could just be a difference in the assembly plants.
You may want to pose the question in a post! JIm |
05-09-2006, 01:47 PM | #7 |
Not a bad nut after all..
My '72 had the two port control. The replacement has three ports, but I haven't installed it, yet.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
