Sb 400 club
i got my truck up at my school to do the t stat housing and fluids all around and tighten up the tranny crossmember and it has rained for two days straight. it is outside under a cove but i hate seeing it all wet as this is its first rain since july 04!!
any ideas on how to fix a leaking t stat. it pisses when i rev it and it has leaked all over the manifold!!! and now stained it. any tips for cleaning off the bult up it is a edelbrok manifold
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
#2 | |
Re: rain sucks
The stat bore in my Performer intake was cut too deep which allows the stat to sit too low and not seal. I took a piece of 0.032 in. stainless safety wire and formed it to fit in the bore under the stat which raised it enough to compress the gasekt. This fix has worked for several years on my daily driver. |
Sb 400 club
Re: rain sucks
thanks alot man
any other ways ?
Insert Witty Text Here
Re: rain sucks
You might have a warped housing. I would replace it.
Fel-Pro makes a premium thermostat housing gasket that fixed one I had that always leaked. I won't use anything else, now. Instead of being made of paper, it is a piece of blue plastic that looks like it has a red silicon bead around the perimeter. I have been able to get them in all of the local auto parts stores for around 4 or 5 dollars. Just ask the counter person for the most expensive thermostat housing gasket they have, and that will probably be it. ![]() Slonaker |
Re: rain sucks
I bought a Mr. Gasket thermostat housing with a O-ring in it. Worked perfect untill I removed it, put it back on and OVERTIGHTENED IT! Then it leaked like a siv. So I took it off again, put a light bead of blue silicon on the O-ring and its been 6 months and not a single drop!
I think the housing was like $5-12, well worth it. If you get the one with the O-ring be careful not to overtighten it!
Anthony 07 Tahoe LT 70 Chevelle 450HP 383-TH400 77 GMC Royal Sierra~Resto in progress~ |
Sb 400 club
Re: rain sucks
wow seems that the p O did not like lock washers!! non on the t stat tranny bolts oil pan any were!! so i re tightend it and leak stopped!!
