05-03-2006, 01:04 AM | #1 |
dumb question
Did these 4X4 Blazers have front and rear swaybars? Mine doesnt have either.
If it aint broke..............fix it till it is. www.fast77.com 1972 - 330 hp crate, 11" lift with 39x18 mickeys. 3/4 ton, cross steer, 4 wheel disc brakes 1996 Z71 w/ 35's Last edited by makovai; 05-03-2006 at 01:04 AM. |
05-03-2006, 01:43 AM | #2 |
Iron Thunder
Re: dumb question
i don't know about the swaybars, but i do know, there is no such thing as a dumb question. if you don't ask you won't know.
05-03-2006, 02:25 AM | #3 |
Re: dumb question
NO, not from the factory.
Some folks are using sway bars from mid 70s trucks and modifiyng them to fit/work on our year Blazers. Check the FAQ, should be some info there I would hope.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
05-03-2006, 09:09 AM | #4 |
Re: dumb question
I put some very flexy Alcan front springs on my '71. To compensate for the tippy nature of the soft springs I also installed a mid-70s swaybar. As 71jimmy mentioned, I think there's a FAQ on this. I know BobK made some nice ones. Here are a couple of pictures of the mounts I fabricated and a link to more if you are interested.
Link to fabricating swaybar mounts
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod Last edited by 71RestoRod; 05-03-2006 at 09:09 AM. |
05-03-2006, 10:51 AM | #5 |
Re: dumb question
Very nice work.....
I was just making sure i wasn't missing some suspension, that is posed to be there. I'll probably work on adding them myself when i make my torque bars. I can kill tippy and axle wrapup all in the same project
If it aint broke..............fix it till it is. www.fast77.com 1972 - 330 hp crate, 11" lift with 39x18 mickeys. 3/4 ton, cross steer, 4 wheel disc brakes 1996 Z71 w/ 35's |
05-03-2006, 10:58 AM | #6 |
Re: dumb question
Nope no sway bars on First Gen Blazers
I added a front one from this company: http://www.addco.net/ But now that my K5 is a trailer queen I don't use it anymore.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
