Old 05-03-2006, 02:04 PM   #1
67 cst swb
67 cst swb's Avatar
68 4X4 3/4ton steering question?
On a 68 3/4 ton 4X4, Is the steering arm that is attached to the steering knuckle the same from Manual Steering to Power Steering? This is not the tie rod ends that are attached to the gear box, but the pieces are on the other end of those short tie rod ends?
Thanks in advance...
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 05-03-2006, 05:01 PM   #2
Erl
Erl's Avatar
Re: 68 4X4 3/4ton steering question?
No, the manual is longer and takes a different rod end. The power arm on a 69 is shorter. The longer arm will work, but you must use another GM rod end.
Erl
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 05-03-2006, 08:12 PM   #3
Southedisto
River life......
Southedisto's Avatar
I have a 72 jimmy with manual steering, and I used a 85 diesel drag link with no problems.
Southedisto is offline   Reply With Quote
