2 for 1 thread! 1-Q? and Project Updates
Ok I've got project updates along with a pretty simple Q? (I hope)
>Q? - I need the dimensions/specs for the lumber for my wood floor? Anyone know the specs? I know it's 1x6 but I need the specs for the recesses for the strips and exact lengths for the boards. I can probably figure it out but I don't mind free info. ![]() Now on to the important stuff... >Project updates w/pics: As you can see the grille leaves something to be desired. The fitment leaves a gap at each end between the front stainless trim and the grille, revealing the filler panel. If I were to push it forward it would then poke out in the center of the grille leaving a large gap. It's not completely adjusted as of yet but you can see the problem I am running up against. I'll take up some more adjustment and see how it looks. (also note this was all done at 11:45PM last night) ![]() ![]() ![]() These are shots from the front. I am satisfied with "the look" from here. ![]() ![]()
-John II "A Little's Good! A Lot's Better! & Too Much is Just Right!!" -1978 Chevy C10 Stepside 350/4sp/12 bolt -1967 Nova 2dr HT & a couple others... ![]() |
Until Seventy Times Seven
Re: 2 for 1 thread! 1-Q? and Project Updates
Here's some specs Courtesy of MAR-K, one of the board sponsors: http://www.mar-k.com/bedwood_dimensions.pdf.
Wood is Good... ![]() I know what you mean 'bout the grille profile not matching the profile of the opening. Is there enough adjustment to purposely recess the grille further into the opening to see how it might look and show off more of the opening all around. Regardless, it's coming along and looking good... ![]()
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
Rodz thanks for the link.
If I sink the grille much further the ends will be sunk past the fascia and will leave an opening. I am thinking about fixing the center and pushing out on the ends to maybe make it conform better to the opening. I'll let you know how it goes. Probably tonight again. Also, I hope no one took my comments about the grille wrong. The actual physical material quality of the grille is flawless. It's the installation and possible design of it to fit the grille area that is the problem. TBC.... ![]()
Sb 400 club
yeah they do not fit right from some companies. however it looks really nice man sweeet truck
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
