05-03-2006, 02:53 PM | #1 |
2WD Jimmy
Clutch linkage questions
The attachment is a picture of part of my clutch linkage. This is the peice that bolts to the engine block that supports the Z-bar on the engine side. It is an NOS item that I purchased years ago. You can see the felt seal below the ball joint... my question is this, is there supposed to be some kind of an O-ring on that ball joint where that groove is machined around the circumference?
Also, anyone got a picture of the rod going into the cltch fork? Im using a GM heavy duty clutch fork but there is no hole in the end, just a dimple? Thanks in advance... Tom |
05-03-2006, 03:50 PM | #2 |
Re: Clutch linkage questions
perhaps a "C" clip ???????
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
05-03-2006, 07:57 PM | #3 |
The groove is to hold grease since the "Z" bar has some movement relative to the engine in addition to the clutch release motion.
Jim |
