Old 05-03-2006, 04:38 PM   #1
derail
derail's Avatar
rear brakes locking up
I am having a problem with the rear brakes locking up on my '65. I have the e.c.e front disc conversion with spindles,booster,and everything else. The rears are drums from a '72? for 5 lug wheels. Everything on the front and back is brand new including drums, cylinders, etc. The problem is.... when I first bled them (after I bench bled the m/c) I could not get brake fluid to come out of the rears. When I disconnected the brake lines from the rear, there was fluid to the cylinders. So I hooked them all back up and drove it like that for a little while. The brakes were o.k. but not like I would have expected for the upgrades. So, last weekend I had my daughter help me bleed them again. This time, the rears had fluid coming out of the bleeder valves, but the pedal would only go about half-way to the floor. The fronts bled fine. Now if you even barely tap the brakes going down the road, the rears are locking up. I called e.c.e and we have determined that it is not because the piston in the prop. valve is stuck one way or another. I am going to re-bleed them this weekend when I get some help, but in the meantime, any suggestions? Thanks. -Justin
derail is offline   Reply With Quote
Old 05-03-2006, 05:04 PM   #2
welsh kev
welsh kev's Avatar
Re: rear brakes locking up
Try 5 bags of cement in the bed!
63 GMC fleetside, 305 V6; over-built, over thirsty and over here!
welsh kev is offline   Reply With Quote
Old 05-03-2006, 05:56 PM   #3
Chevrolet4x4s
Chevrolet4x4s's Avatar
Check and see if the breke adjusters are ran out too far try letting them off a little bit.
Hope this helps.
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 05-03-2006, 06:17 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
May be a dumb question, but is there any way that you may have swapped front/rear channels? I've seen that happen before (don't ask ) and it acted like your description.
Frizzle Fry is offline   Reply With Quote
Old 05-03-2006, 06:35 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Like fred says it does happen. Also check that the master is for disc front rear drum and that you have a functioing proportioning valve for Disc/Drum setup. The large reservior is for the disc side.
dwcsr is offline   Reply With Quote
Old 05-04-2006, 02:12 AM   #6
derail
derail's Avatar
Thank you guys for the replies. I will check and double check everything. I'll try everything suggested except the 5 bags of cement. I'll let you know how it turns out.
