05-03-2006, 07:57 PM | #1 |
WTB parts to finish project!
Just finishing for parts before turning to a vendor. I need the following:
Right front fender for 72 Rear cross sill (wood bed) Front bed panel(wood bed) Wheel housings P/S remote resevoir for big block Also need the spring that is in the automatic Column (tilt) for the gear shift Lost mine somewhere along the line. Does anyone know if this is the same spring as in the non-tilt column? Thanks Allen.
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
05-03-2006, 08:12 PM | #2 |
Re: WTB parts to finish project!
I may have the spring/s for the auto tilt, if you or someone can post a pic of this thing.
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
05-03-2006, 09:21 PM | #3 |
Greenhorn, I don't have a picture. All I have is a distant memory of what it looked like before I lost it. Maybe someone else can come up with a picture.
Allen
05-03-2006, 10:27 PM | #4 |
Al, tell me if this is the spring. All the other little parts are also off a tilt.
05-03-2006, 10:29 PM | #5 |
Post Whore
the front panel you need for fleet or step?
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons |
05-04-2006, 06:37 PM | #6 |
Greenhorn, I believe that is the tilt spring, that one I have. The one I am missing is for the gear shift and is much smaller.
05-04-2006, 06:38 PM | #7 |
71SWBCHEVY, the panel would be for a fleet side.
05-04-2006, 07:53 PM | #8 |
Is it these springs inside the housing?
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. Last edited by greenhorn male; 05-04-2006 at 07:55 PM. |
05-04-2006, 11:09 PM | #9 |
Truck Farmer
Allen, I have one nice wheel housing and the BB reservoir. Both for $50 shipped. Chuck
Arizona rust free sheetmetal |
05-04-2006, 11:22 PM | #10 |
I have the tilt spring from inside the shift bowl. $6.50 to your door.
I can PM you my mailing address. Thanks - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
05-05-2006, 09:46 PM | #11 |
Hey Guys, Let me try to describe this spring a little better. It is the one that goes with the gear shift (selector lever). It is located under the very end of the lever where it extends into the column. When you pull the gear shift toward you to release it (shift) you are pulling against this spring.
Allen
05-07-2006, 12:10 AM | #12 |
Yes Allen, that is the one I can ship to your door for $6.50. 5/16 diameter by 7/8 long. It goes under the shift lever to provide tension putting the lever into the detent gate to prevent slipping out of Park and reverse without pulling on the lever.
Let me know - Bob
