![]() Join Date: Nov 2003
Help with rear coil spring upper bolt
I am trying to remove my rear springs to install my bags. Is the upper spring bolt attached to a nut inside the frame? If so how do you get in there? I really wish I had a hoist!!!!
Does anyone have a bare frame that they could take a picture of for me so I can see exactly what I am dealing with?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Re: Help with rear coil spring upper bolt
There should be a nut inside the frame rail. Where the crossmember "splits" to go to the upper and lower portions of the frame rail is where the nut is. If you haven't done a c-notch yet you should be able to get to it from the front or the back with a standard wrench. If you have done a c-notch you will have to go from the front.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Thanks for the picture. I think I can get this tackled tomorrow.
No Problem, I'm just waiting to see you get your Jimmy bagged to give me motivation to get to work on my Blazer.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 05-04-2006 at 11:20 PM. |
Thanks for the help, I got it off. I used my wife's mirror, I hope she doens't notice the greasy finger prints!
Sweet! I'll be watching your other thread for progress pics. I can't wait to see it laid out.
