Old 05-04-2006, 11:45 AM   #1
Green Machine
Green Machine's Avatar
Are 31 X 10.50 X 15 Tires Unsafe for Front of 2WD ???
I am trying a set of 31 X 10.50 on my 68 2WD. The wheels are 8.5 wide with 3 5/8 back space. Pretty large offset to outside, they were on a 4wd blazer.
Truck rides rougher and gets "twichy" on the front unless road is real smooth.
They do need balanced, but they are going to be driven by my 15 year old son soon to get his licence.
We like the looks and how the fill up the wheel well, but I don't want him to wreck a newly restored truck or get hurt because we put too big or the wrong tires on there.
Please offer any suggestions here - Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-04-2006, 12:57 PM   #2
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Are 31 X 10.50 X 15 Tires Unsafe for Front of 2WD ???
I have 31 x 10.5 x 15 BFG Long Trail radials on my 67 2wd with no problems, rides smooth and straight. Maybe you need to play around a little with the tyre pressures as well as have them balanced until you find a pressure that suits. I run muine at about 30psi.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 05-04-2006, 01:06 PM   #3
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
Does the truck have a front sway bar?
I agree with Lippyp that you need to get the tires balanced and try different pressures, but a sway bar is the best, cheapest handling modification you can make.
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 05-05-2006, 03:57 AM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
I only fitted my sway bar recently, even without one it still rode fine, it was however like cornering in a small sailing boat before the sway bar was fitted. Now much less lean and more confident cornering.
Phil
'67 C10 long fleet.
Old 05-05-2006, 08:19 AM   #5
67sub
67sub's Avatar
A steering damper will probably help alot. Took a whole bunch of the jumpiness out of mine. Good Luck
2004 Kawasaki KLR
Always looking for a cheap driver
67sub is offline   Reply With Quote
