Progress = 0%
What is the best way to bleed (fill) a new brake system (completely empty). I bench bled the master cylinder so it's ready to go. I've been told to get one of those vacuum pumps and suck the fluid through at the wheels. Any better suggestions?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
![]() Join Date: Jun 2000
I've recently discovered Speed Bleeders. They are simply bleeder valves with a little check valve inside and some gunk on the threads to seal them up. Makes for easy one-man bleeding--just open it up, walk to the cab and pump the pedal until you see clear, bubble-less fluid coming through your clear tubing that you attached to the bleeder, and walk back and close the valve. Pretty darn easy. They cost about $12 a pair, though. I see them at all the parts stores now. Good luck!
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
![]() Join Date: Mar 2002
Hey Slammed,
I bought the Vacuum Pump to bleed the brakes on my truck. It cost about $30 and worked well. If you work alone it is a must. This method also is good for containing the brake fluid, important with a nice paint job like yours.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
I like the mityvac, it works good and doubles for working on your adjustable vacuum advance on distributors. Another good thing I found out that to me is worth $30 alone, one of the attachments works great for testing Holley power valves. Would recommend it highly.
Oh did you run exhaust pipes yet to your sanderson headers? The pictures you sent looks like the starter side could be rough, was just curious if was the picture playing tricks on me.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End Early Classics 6 Lug Disc Brakes and Spindles All Stainless Lines Last edited by Denny; 07-30-2002 at 02:44 PM. |
Between Trucks...
i got this one man brake bleeder kit for all of $5 if my memory serves me...
little bottle with a fitting on the top for some tubing and a magnet, hook it up to the bleeder valve stick the magnet/bottle to the frame above the bleeder valve and pump the brakes till there's fluid in the bottle... ![]()
Beat it to fit, Paint it to match... ![]() |
Strongman Garage
![]() Join Date: Apr 2000
i got one of those at harbor freight but havnt used it yet.... do they work good sinister?
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
chevelito
Here's the one from harbor freight....sale $2.99
http://www.harborfreight.com/cpi/cta...emnumber=37201
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
Progress = 0%
Well, I went ahead and bought the mytivac vacuum pump. It worked great. Although I had to put some teflon tape on the bleeder screw threads because too much air was leaking past them. Can't wait to try them out on the road........ better get that engine hooked up!
Between Trucks...
hey 68SWB4x4, it's phat, now i don't have to scream at the old lady to pump the brakes anymore...
