![]() Join Date: Apr 2005
How do you decode frame #'s???
I pulled this number off of my frame - 2 S 161358. Can anyone tell me what it means?
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: How do you decode frame #'s???
It's a 72 frame from the St Louis Plant Assembly plant. The last 6 numbers are the last six of the original vin number...thats just one of the many things needed for a matching numbers vehicle.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 05-04-2006 at 08:28 PM. |
#3 | |||
Union Electrician
Hi Rod How have you been? Where exactly are the numbers at to check mine? Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Randy, they will be on the top of the drivers side frame, just slightly to the rear of where the steering box mounts. Kind of hard to see as they are usually covered with rust but willl show if sanded a bit.
Cool thanks guys. Byrd - doing well. Trying to get my 48 back together so I can make it up to Chikenwings "shindig".
Where's my beer?
VIN on frame, pic courtesy of Longhornman......
Paul How do you make the invisible, visible?.........You take it away. |
