Old 05-04-2006, 08:51 PM   #1
jsbgump
Gone Fishing
jsbgump's Avatar
Angry Fuel gauge still don't work after fix a guage resistor
I am lost. What else can i do I am fed up with this stupid gauge. Help!!!!!!!!!! If I remove the wire from the fuse block or the sending unit it goes past full. Any one have any ideas?
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-04-2006, 09:18 PM   #2
byrd
Union Electrician
byrd's Avatar
Re: Fuel gauge still don't work after fix a guage resistor
What does it do when you turn the key on? Does it go to past empty when grounded out?
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-04-2006, 09:50 PM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
it stays at about an 1/8th when key is on. I'll try addind a ground to the sender and see.
Build Thread
Old 05-04-2006, 10:10 PM   #4
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Sounds like the sender is bad.
You can pull the sender out,adn take it apart,and clean the inside with a piece of sandpaper 400-600 grit,and sometimes it'll work.Mine did.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 05-05-2006, 12:07 AM   #5
cstanley
cstanley's Avatar
had the same problem. just replaced my sender. it was the culprit. wish i had known that 9 years ago when the gauge stopped working!! it was cake, took about 5 min (not counting seat removal.)
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 05-05-2006, 12:25 AM   #6
junkyardjohn
junkyardjohn's Avatar
I'M PRETTY SURE I HAVE AN EXTRA FUEL GAGE AROUND HERE THAT I'LL SEND YOU FOR POSTAGE, IF YOU WANT TO RULE OUT THE GAGE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-05-2006, 12:55 AM   #7
BowTieMan
BowTieMan's Avatar
How much does a new sending unit cost?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 05-05-2006, 01:04 AM   #8
jsbgump
Gone Fishing
jsbgump's Avatar
I have a couple layin around here and allready ruled that out
Build Thread
Old 05-05-2006, 08:58 AM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
If it goes past full when you unhook it and then to 1/8 of a tank when its plugged back in, then the gage is working and the unit is grounded. Pull your sending unit and you may find that your float has a hole in it and is basically staying in the same place. Or the little box looking thingy is bad.
The other thing you might want to try is putting more than 1/8 tank of fuel in the truck
Sorry, couldn't resist
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-05-2006, 09:05 AM   #10
70c10
67-72 Addict!
70c10's Avatar
I would check the float. Takes a few minutes.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-05-2006, 11:10 AM   #11
cstanley
cstanley's Avatar
i think my sending unit and parts were about $50 from gmcpauls. ordered as stated below...
(CP 72-9300-A) In Cab Fuel Sending Unit6772 - 72 Auto Trans. V8 or 6cyl
($42.95) X 1 = $42.95
Fuel Sender Lock Ring 67-72 ($4.95) X 1 = $4.95
(CP-67-9305) Fuel Sender O-Ring 67-72 ($2.95) X 1 = $2.95
Old 05-05-2006, 01:03 PM   #12
jsbgump
Gone Fishing
jsbgump's Avatar
Well it is the sending unit I have the one for the poly blazer tank conversion and used it to test and it worked with it so the sending unit is bad. I guess I need to get the blazer tank in and run a filler.
Build Thread
Old 05-05-2006, 10:04 PM   #13
roughedup72
roughedup72's Avatar
I had a similar problem when I had my tank repaired, When I put the sendeing unit back in the float fell off inside the tank. I was a B*&&&^ to get out.ordered a new sending unit from chevy duty, Oh I forgot, That place that used to be chevy duty.pretty good price and it came with the gasket,no mo problems.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 05-05-2006, 10:33 PM   #14
Brainchild
Brainchild's Avatar
Like I said,I fixed mine with a piece of sandpaper.Just pulled it out,and pulled the box apart,cleaned the contacts,and put it back together.Worked fine for nearly 2 years now.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
