05-05-2006, 12:33 AM | #1 |
what happened to flint mi
how good are repop fleetside tailgates ?
how do they fit? would you buy another ?
71 swb 2wd fleet frame off in progress 72 4x4 blazer daily driver 70 olds cutlass s mint condition owned by a grandma 56 gmc 2wd project waitng 97 fiance mobile Last edited by tom71; 05-05-2006 at 12:34 AM. |
05-05-2006, 12:52 AM | #2 |
Insert Title Here
Re: how good are repop tailgates ?
I got mine from Wes at http://www.classicheartbeat.com and it fit fine, no probs at all... I have heard some are made of thinner material, but these are supposed to be correct gauge, so I assume it is
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
05-05-2006, 01:55 AM | #3 |
2WD Jimmy
Whether it is a repop or NOS, you will have to do some work to it if you want it to fit correctly. (unless your awfuleasy to please)
It will probably have some twist to take out and the gaps wont be perfect. All that can be overcome... with a little work. Im talking goodmark, it is the right gauge, but you will have to massage it or a nos one. |
05-05-2006, 06:42 AM | #4 |
Stepside or Fleetside?All Stepside gatesa flimsy,IMO,and want to bow real easy.Like they were never intended to stay that nice,
05-05-2006, 07:55 AM | #5 |
EVERY AFTERMARKET TAILGATE I'VE SEEN HAS BEEN... WELL... NOT SO PRETTY GOOD. BUT I'VE ONLY SEEN ABOUT A DOZEN & A HALF INSTALLED THOUGH. PEOPLE CAN SWEAR THEY ARE THE SAME GAUGE, EVERY BIT AS THICK & HEAVY AS A G.M. T/GATE, BUT I'VE NEVER SEEN ONE THAT WOULDN'T BEND IN THE MIDDLE IF A HEFTY CHICK SAT IN THE MIDDLE OF IT. I HAVE SAT FULLY LOADED SMALL BLOCKS ON THE ORIGINAL T/GATE ON MY BLAZER WHILE LOADING ONE FROM THE BONEYARD, WITHOUT BOWING OR BENDING. NOT JUST ONCE, BUT SEVERAL TIMES. THE ONLY AFTERMARKET PARTS THAT I'VE USED THAT WERE AS GOOD AS THE ORIGINALS IS A INST. PANEL, A DOOR LATCH & ROCKERS. TO EACH HIS OWN BUT SOME PEOPLE SWORE PACERS ,VEGAS & GREMLINS WERE GOOD CARS TOO. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
05-05-2006, 01:36 PM | #6 |
JYJ - maybe you need one of these - I have heard that the gates with the letters weigh only about five pounds less than the originals and are pretty good, the gates without letters are much lighter than the originals, depends on supplier, but I have been told this by several vendors when looking for mine. Talk to Mother Truckers, or call Manes Truck Parts for some good info.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 05-05-2006 at 01:44 PM. |
05-05-2006, 02:07 PM | #7 |
Blank
I bought one without letters it fit with no problems but I stepped on it getting in the bed and it bowed I weigh 145lbs??? 6 months later the welds holding the outer skin broke I will not buy another
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi. 1977 Corvette 350-375hp 4speed, silver show car. 2002 S10 xtreme, work truck 2004.5 VW jetta GLI 1.8T 6speed, weekend warrior. 2013 Audi A3 TDI, the wife's car |
05-05-2006, 02:14 PM | #8 |
Insert Title Here
well i cant debate on the strength side, because im not going to test it...lol, i wont let anyone touch it, let alone sit on it..... but lining up wise, it fits great the lines all line up the handle sits in it right and the gaps to the bedsides are even... so looks wise its good. (so far)
05-05-2006, 02:16 PM | #9 |
Insert Title Here
and it looks beter than before...lol
05-05-2006, 02:17 PM | #10 | |
I'm sticking with my originals. Does anyone have a better idea for getting the dents out other than cutting an access panel in the back and then welding it back in? I think they're just too deep and sharp for a stud or screw puller. |
05-05-2006, 02:23 PM | #11 |
Not saying I would never buy another aftermarket but do not leave me alone with oem fleet tailgates.. My aftermarket has mis-alignments before spot welding. I think the molds are worn out and they need more quality control in Taiwan on them. I have no fear of standing on it tho.
Mine has the Chevrolet lettering embossed in it. Last edited by dennislbrooks; 05-05-2006 at 03:10 PM. |
05-05-2006, 02:38 PM | #12 |
Just remembered, I was also told that it would be a good idea on any repop tailgate to re-weld all of the spot welds to avoid seperation there. More work up front, but better than later after its painted.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-05-2006, 03:05 PM | #13 |
A guy with a truck
There is a new generation of repop gates now. Supposed to be much better.
-Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-05-2006, 03:25 PM | #14 |
I looked at the lettered and non-lettered gates side by side at the Carlisle PA swap meet, and the lettered gate was much thicker and heavier. I was told they both came from the same MFG. in Taiwan. I was tempted to buy the lettered gate, but it was raining Saturday and I didn't feel carrying it around.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
05-05-2006, 08:46 PM | #15 |
I bought a 'G.M. Restoration Parts' GMC lettered tailgate from Jim Carter. Just as heavy as the original. I, too, have been told that the smooth tailgates are considerably lighter than the good quality lettered repops.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
05-05-2006, 10:16 PM | #16 |
My son & I talked to a guy from the truck shop at the Portland swap meet & asked him about the plain gates being thinner than the lettered gates. He said Counterpart(which is owned by the truck shop) uses the same tooling & materials for both gates.
05-05-2006, 10:20 PM | #17 |
does the lettering like putting a bead in flat sheet metal give it more strength?
Just a thought? |
05-05-2006, 10:31 PM | #18 |
Roaming around my uncle's machine shop about 15 years ago (he's a rancher in Nebraska), and I see two beautiful tailgates. I'm talking spotless. One from 67-72 Chevy, another from 70's vintage Chevy (also had a ford...but who cares).
I was high school at the time and told him he was sitting on a gold mine. He just laughed at me. Never know what you might find in an old rancher or farmer's machine shed...Wish I had either of them now!
'72 Chevy K-20 Crate 350, SM465, 4.10's |
05-05-2006, 10:46 PM | #19 |
heres my unlettered goodmark...a little lighter than stock..but for 200.00
05-05-2006, 11:01 PM | #20 |
i recently bought a parts truck {stepside} with a Gorden repro tail gate. it is the lightest most flimsy thing i have ever seen. i'd be afraid to set a beer on that tailgate. i'd to stay away from the gorden sheetmetal , it has a stamp real similar to the goodmark stamp.
common sense isn't so common anymore |
05-05-2006, 11:08 PM | #21 |
Chevy Forever
This subject has come up before and I have a OEM tailgate and a repro with the lettering I wieghed them both now granted my latch assy. is still in the OEM but it still wiegh's 10 punds more then the repro. This is just my experiance. I hope this helps.
My first love 1971 C20 Hugger orange Getting face lift and heart transplant .30 402 BB /TH400 and GV Wifes car 1969 Chevelle SS 396 325hp/TH400 Factroy A/C Automatic w/ Floor shift console. restored. |
05-05-2006, 11:50 PM | #22 | |
05-06-2006, 12:38 AM | #23 |
Happy Camper
Stay away, stay far away... This is what it looked like just days after install.
RIP El Jay! Love you brother! |
05-06-2006, 12:39 AM | #24 |
Happy Camper
I know... it looks better than the rest of the truck... SHUT UP!!!
05-06-2006, 09:53 AM | #25 | |
Truck Parts Mfg.
Just take a scales and weigh the repo and compare to the weight of an original. Same gage metal will weigh the same regardless of what the supplier says. IMO the reason the repo gates are lighter gage and poor quality is the American importer is only interested in getting the cheapest part possible. They import hundreds at a time and save a few cents by using cheaper methods and materials. The result is the buyer gets a good looking part that is not made well and will not be durable. The overseas factory is probably making what was ordered. Mar-Ktech
GET MAR-K Quality! Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks |
