05-05-2006, 01:17 AM | #1 |
Active Member
4.5/6 drop.
Has anyone gone with 4.5/6, what ive got so far is 2" drop front coils and 3" drop rear coils. I was thinking of going with the 5" spring in the back and 1" block. and 2" front drop spring with drop spindles.
What things will i need to change in order to keep my truck driving straight and not ruining other suspension parts? my headers are full length and i worrie about clearence for those because its a long box! or am i just hallucinating?
S.h.i.t happens when you party naked. |
05-05-2006, 07:02 PM | #2 |
Active Member
Re: 4.5/6 drop.
anyone?
05-05-2006, 07:34 PM | #3 |
Gone Fishing
Re: 4.5/6 drop.
You will need the adjustable panhard bar and a rear shock relocater kit
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
05-05-2006, 11:49 PM | #4 |
Re: 4.5/6 drop.
Depending on the brand & type of headers, you may/may not have clearance issues. Stick a 2x4 under your headers & exhaust @ the current ride height. If it looks too close, you'll have problems & will need to consider swapping back to manifolds or shorty headers.
My 68 has dropped spindles & ~3" shorter coils up front w/a 27.5" front tire diameter. For reference, you have to remove the plate off of a standard 2-ton floor jack to roll it under the front crossmember. I don't have problems @ that height but it had headers that had to be removed. It has bottomed out in a construction zone before, typically it just buzzes the tops of the front inner fenderwells occasionally. For the rear, @ a 6" drop (5" coil + 1" block) you can get away w/modifying your stock panhard bar or get an aftermarket adjustable one. Shock relocators would be good but not mandatory because it's technically only a 5" drop (blocks don't alter the travel distance on the shocks). Even then, you can relocate the stock brackets or use shorter off the shelf shocks. 6" drops will work w/o a c-notch but you will prob need to remove or relocate the bumpstop.
05-06-2006, 12:26 AM | #5 |
Active Member
Re: 4.5/6 drop.
heres how low they hang. this was before the 2/3 drop and 18's i dont know if you can get an idea from this pic, but here it is anyways.
05-06-2006, 05:48 PM | #6 |
Re: 4.5/6 drop.
It's hard to tell from pics. Drop spindles will lower the current ride height either 2.5" or 3" (depending on the spindle brand).
Stack some wood pieces together to get the same thickness as the amount of spindle drop. Slide the wood under the headers & get a buddy to bounce on the front end w/you (we stand on the front bumper & hold on to the opened hood to keep from falling). If the headers hit the wood..... you'll have your answer.
05-19-2006, 01:01 PM | #7 |
JamesChurch13
Re: 4.5/6 drop.
who sells 3 inch drop spindals? I can only find 2.5s
HG/FTW!!! Current vehicle collection: 1968 Chevy C-10 SWB Fleet Side, 327ci, TH350 (MD) 1987 Chevy Dually Quad Cab, 427ci, TH400 2008 Buell XB12SS, 1203cc 2006 YZ450F Wheelie Machine! 1997 Suzuki Bandit 600cc And the Wife has some cars I pay insurance on and use to transport the kids!(01' Grand Cherokee and 06' Pontiac Grand Prix) |
05-19-2006, 11:39 PM | #8 |
All Praise RANDY!!
Re: 4.5/6 drop.
Bell Tech has 3" droppers! Not sure on the part # tho!
05-20-2006, 12:15 AM | #9 | |
JamesChurch13
Re: 4.5/6 drop.
05-20-2006, 01:38 AM | #10 |
Re: 4.5/6 drop.
Summit & Jegs each sell BellTech spindles. DJM also makes a 3" spindle.
05-20-2006, 03:58 AM | #11 | |
JamesChurch13
Re: 4.5/6 drop.
05-25-2006, 05:25 PM | #12 |
Re: 4.5/6 drop.
Carrzy4, If you go with 4" springs and a 2" block (rear) you won't need the shock relocators or the adj. bar. This is what I run with out any problems.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
05-25-2006, 10:24 PM | #13 | |
Watch out for your cornhole !
Re: 4.5/6 drop.
BellTech 3 inch drop spindles for 71-72 trucks. Straight bolt on, no mods needed. In stock and ship tomorrow if you want... http://store.summitracing.com/partde...5&autoview=sku
05-26-2006, 01:56 AM | #14 |
Re: 4.5/6 drop.
Thanks TX.
05-27-2006, 04:38 PM | #15 | |
Re: 4.5/6 drop.
Thanks Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
05-28-2006, 06:36 AM | #16 | |
Re: 4.5/6 drop.
Summit has them in stock too.
05-28-2006, 09:08 AM | #17 |
Re: 4.5/6 drop.
No c-notch with 6" drop?
05-28-2006, 09:18 AM | #18 | |
67 is sold
Re: 4.5/6 drop.
Coil spring trucks anyway, I assume same for leaf. |
