Old 05-05-2006, 04:47 PM   #1
karl
karl's Avatar
700R transplant
I just aquired a 700R transmission out of an 85 z28 camaro. how do i go about installing it in my 77 short half ton. it has a 350 engine and 350 trans. do i have to shorten the driveline? what about a flexplate? what about the crossmember ect.? thanks
karl is offline   Reply With Quote
Old 05-06-2006, 08:37 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 700R transplant
You will need to drill holes for the transmission crossmember. The crossmember need to be moved back a little over 2". Visit this website for exact dimensions. http://www.tciauto.com/tech_info/trans_dims.htm
The driveshaft will have to be lengthened. Trucks all havebr long tailshaft tranny's. Most cars had short tailshaft tranny's. The 350TH oil lines are the same. Use the correct bracket to install the TV cable.
Read this page for 700R4 swap information. http://www.transmissioncenter.net/SwapInformation.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
