Old 05-05-2006, 08:13 PM   #1
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Found out not all 73-87 side windows interchange
Actually, the glass appears to be the same but if the track is different the window will not roll up completely.
I discovered this yesterday while I was trying to replace the driverside window in my '86 GMC 1500 because Wednesday I was mowing the lawn next to my gravel driveway and when I got done you can imagine what I found. So, after retrieving a window from the local junk yard I got the thing installed yesterday morning.
I'd noticed that the track looked different on the window they gave me. It was more like the track in a 67-72 window but figured it wouldn't matter. Well it would only roll up about 3/4 of the way and after spending the rest of the morning taking it out, getting another window with a track that matched the original, I finally got it right.
Any one else run into this?
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 05-06-2006, 08:47 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Found out not all 73-87 side windows interchange
Yup, been there done that. I bet you grabbed a window out of a 73-76?
bigblock73 is offline   Reply With Quote
Old 05-06-2006, 09:38 AM   #3
Old Yeller 1970
DON'T TREAD ON ME
They already had it pulled so there's no telling what year model it came from. They had it marked as an '81-'87 window but that is undoubtedly false. Judging from the track style and amount of rust I would guess you are right about the '73-'76 age though.
Old Yeller
Old 05-06-2006, 11:15 AM   #4
nivimar
nivimar's Avatar
Now, if the windows are diffrent are the doors still interchangable I have a 76 and soon to put shaved early 80's doors on. I mathced fit them and they were good but now i have doubt's.I heard all these trucks are the same from the doors back?
nivimar is offline   Reply With Quote
Old 05-06-2006, 12:16 PM   #5
EJC78
No Life Like Low Life
EJC78's Avatar
Hey guys quick question is the curve of the glass different between the different years, because I ordered the onepiece window kit and the glass that I recieved has a greater curve radius then the stock one. I was thinking that the window kit may have been designed for a later year truck. Mine is a 78
Eric
1978 Chevy Scottsdale
1960 Impala ZZ4
1965 Buick Riviera GS
2011 GMC Sierra Denali
EJC78 is offline   Reply With Quote
Old 05-06-2006, 12:29 PM   #6
Crank
Crank's Avatar
I believe all the doors will interchange but the glass wont, but the outside diameters are the same... EJC78 Where did you order your one piece glass from, I'd like to look into one for my '79 Crewcab, thanks.
Brandon
Crank is offline   Reply With Quote
Old 05-06-2006, 12:34 PM   #7
82c10
needin' money
Brandon
he got it from brother's
http://brothersonlinestore.com/prodi...number=OPWK800
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 05-06-2006, 03:50 PM   #8
EJC78
EJC78's Avatar
Yep thats where I got the kit from
Eric
1960 Impala ZZ4
Old 05-06-2006, 08:42 PM   #9
Old Yeller 1970
DON'T TREAD ON ME
I think the doors should all interchange and it looked to me like the glass (in my case) was shaped the same. But since the track was different then I would have to say the window regulators are different and will have to match the track style based on year model.
Old Yeller
Old 05-07-2006, 02:04 AM   #10
nivimar
nivimar's Avatar
You know I talked to alot of local glass shops and they saild a 73-87 glass kit would not work.If you think about it all you need is a pre cut piece of glass or template out of cardboard and a specially made channel.Brothers want's way to much for this kit.I was thinking more like $350.00 It still looks great though.
Old 05-07-2006, 12:04 PM   #11
SCOTI
SCOTI's Avatar
Originally Posted by nivimar
..... If you think about it all you need is a pre cut piece of glass or template out of cardboard and a specially made channel.....
I don't mean to be an a**, but if it's that easy, there's several members on this board that will take the first few sets off your hands after you go into production. Sounds like you have it figured out so it shouldn't take long.
It's easy to sit back & say "all you need is....."; it's a whole different level of play to actually do it. Engineering time, parts development, tooling costs, & packaging all cost money.
.... Brothers want's way to much for this kit.I was thinking more like $350.00....
How much does it cost for just 2 stock windows, 2 vent-wing windows, all the window channel fuzzies & felts? My guess is more than $350.
I feel Brothers has been the only source to step up to the plate so far & they deserve props for that (even if their kit isn't flawless @ this point). Once people get these, someone will try to build a better mousetrap & prices will drop..... just hope that quality improves @ the same time.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-07-2006, 12:43 PM   #12
SSC's76
No No
SSC's76's Avatar
Well they do interchange but if you use the older window in a newer truck or vise versa you also need to change the vent window assembly to match the same year glass. If you do this it all works/fits fine.
In my 86 somone had broken the vent window out to try and steal what they thought was a CD player sitting on the dash. When they found out it was an ancient radar detector they left it. We used one of the spare vent windows from the 76 and one of the spare windows from it as a replacement. Works fine!
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 05-07-2006, 02:12 PM   #13
bigblock73
yeller
bigblock73's Avatar
Right on Scoti, I couldn't agree more.
Old 05-07-2006, 03:25 PM   #14
Chevrolet4x4s
Chevrolet4x4s's Avatar
Quality costs but truthfully regardless of the price I like my vent windows.Have always hated the fact that they did away with them in new stuff one more reason to buy an 87 back vehicle.
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 05-07-2006, 04:58 PM   #15
Old Yeller 1970
DON'T TREAD ON ME
Did you have to change regulators or are they all the same?
Old Yeller
Old 05-07-2006, 06:05 PM   #16
SCOTI
SCOTI's Avatar
Shane
I don't dislike vent windows. I do hate the whistles you get when the seal isn't optimum. That's the strong point for me, 1pc windows eliminate the main source for wind noise as well as the #1 point of entry for any beginner thief.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-08-2006, 05:10 PM   #17
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I have already been where the company that makes the kit for Brothers is. It would have cost me $350 for a set of JUST the glass and they wouldn't touch it unless I could purchase a MINIMUM of 10 sets at one hit, AND if my mold was off, I had to EAT the other 10 sets and Do it all over again 10 set at a time.... Which is why you don't see mine availible yet...
This doesn't include all the new hardware, and weatherstripping. Trust me, $775 is a reasonable price for markup on this item. If I got mine put together, I wouldn't dare sell it for less than $600... at a minimum.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-08-2006, 08:34 PM   #18
SSC's76
No No
SSC's76's Avatar
The 86 regulator stayed. The only difference between the different year regulators is the crank peice the handel attaches to, it's 1/2" or so longer to accomodate the different (larger) style door panel.
Old 05-09-2006, 12:02 AM   #19
Old Yeller 1970
DON'T TREAD ON ME
Thanks for the info. It'll probably prove useful somewhere down the road.
Old Yeller
