![]() Join Date: Mar 2003
I've got a 72' GMC with the 402BB, which I'm restoring which has the power steering pump with the separate reservoir. I need to replace the larger hose going from the pump to the reservoir. I noticed at the bottom of the reservoir is a little smaller fitting than at the pump fitting where the hose goes on. I've heard in the past it takes a special type of hose.The parts man wanted to sell me regular heater hose which I had on it and it swelled.What kind of hose do I need and what size is it? I also need to replace the bulb which is on the outside cab light over the back window.The number on the old bulb has GE 94 on it.I checked the auto part store today and he said he didn't have one like it and the GE 94 # doesn't cross over to any other bulb.Does someone know what bulb and part number I need? Thank you everyone for your help.
its all about the +6 inches
Re: power steering hose and light bulb ?
I *think* I've used a regular 1156 bulb in there, but it's been so long ago i may be mistaken.
As for the hose, go to NAPA, IIRC, the hose you need is 5/8, they should be able to get that in tranny line hose. |
blood type; Retumbo
isnt a 94 the same base as a 1156, just with a smaller globe? isnt 94 still a good #?
Here is what I did for the reservoir hose.
Original parts group has the hose. Part number is CH20278. $25.45 each.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
Do you have the original parts group phone# or website,I tried and couldn't find it and the #94 bulb I have has 1 filament and 2 conectors at the base and the 1156 is different.I believe it has 1 filament and 1connector at the base.Any other suggestions thank you all.
