Old 05-06-2006, 12:19 PM   #1
obsesive23
Who me?
obsesive23's Avatar
Door panel questions
Can you put panels off a 78 on the 73-75 style doors? I haven't tryied yet and just noticed that my wife bough new panels for 78 and I put doors off a 75 on her blazer. Just wondering if anybody has done this? I'm almost done converting her blazer and would like to make sure that they can fit before I paint it.
Living the dream
72 2WD Blazer, under going porter built surgery
67 GT Mustang fastback
67 Mustang coupe C/S clone
64 Falcon sprint hardtop
obsesive23 is offline   Reply With Quote
Old 05-07-2006, 11:28 AM   #2
obsesive23
Who me?
obsesive23's Avatar
Re: Door panel questions
ttt
Living the dream
Old 05-07-2006, 01:49 PM   #3
eagle23
Active Member
I had a similar question in June 2004, and this is what BigBlock73 told me:
"Any door from 1973-1987 will fit any truck from 1973-1987. The difference between the doors are the door panels and guts. 1973-1976 doors are unique to themselves. The guts and door panels will only fit doors of the same years. 1977 on up, all parts interchange I believe."
Hope this helps. I'm sure others know more than I do
These are the pix I got back then from Capt Kaos (I hope they load; first attempt here )
eagle23 is offline   Reply With Quote
Old 05-07-2006, 01:52 PM   #4
eagle23
Active Member
For clarity, the top pix is the 73-76, the bottom the 77-87. Note the smaller door panel openings on the earlier model.
Again, others may know more than I do...in fact, I KNOW they do
Old 05-07-2006, 02:10 PM   #5
bigblock73
yeller
bigblock73's Avatar
Thanks Eagle23
I put 77+ door panels on my '73 doors...but the window stalks are too short and will not allow you to put the handle on the door...without caving in the door panel in that area...and scratching it all to hell.
You can find 77+ guts and put them in...but keep in mind the track the window slides on inside the door is different too...and you will have to replace it with a 77+ unit as well (it is spot welded in).
Hope this helps some more.
bigblock73 is offline   Reply With Quote
