Old 05-06-2006, 03:17 PM   #1
GMC 3
which complete wiring harness?
I have a 70 swb 2wd pickup w/ 350, hei, one wire alternator, and a floor mounted shifter. other than that it is basically stock. I want to use the blade style fuses, and i don't have much auto wiring experience. I was looking at the universal kits but they like a pain because it doesn't come with the connectors or anything for under dash. I basically just want something i can mount in the stock location and plug in. any suggestions. Painless? RonFrancis? thanks
GMC 3 is offline   Reply With Quote
Old 05-06-2006, 09:00 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: which complete wiring harness?
I think painless has a kit just for our trucks
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-06-2006, 11:41 PM   #3
Aarons72s
I installed one of the painless wiring kits into a truck I built for my former employer. I found that this kit is a pain to put together. I have rebuilt old harnesses before and even with previous owner modifications, I have found it is easier to rebuild the old ones. But if you really want to use blade fuses that is probably the best way to go. Just plan on spending quite a few nights putting the harness together. You will have to use a few of the plugs from the original dash harness, a plug for the hei and will have to order a seperate kit if you have a/c. I hope this info helps you out. If you have any more questions I will try my best to answer them. Good luck.
Aarons72s is offline   Reply With Quote
Old 05-07-2006, 01:13 AM   #4
Blue85
Oilfield Trash
Blue85's Avatar
3 words for you man, Painless, Painless, Painless!
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
