Old 05-06-2006, 03:31 PM   #1
shelby987
shelby987's Avatar
stuck valve?
Some of you may have the thread I made regarding sea foam, well this morning I did my second running of sea foam through the intake. When I went to fire the truck up to flush all of the carbon out, I had what sounds like a stuck valve or lifter in the front of the engine, its a very audible 'ticking'.....not sure how running this through the intake would make a valve stick. Any sure fire cures for stuck valves?
As I type this, I am thinking maybe I should pull the plugs to make sure I didn't just badly foul one of them?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 05-06-2006, 04:51 PM   #2
cdowns
cdowns's Avatar
Re: stuck valve?
you might of melted a valve or maybe cracked a piston ring from the disturbed carbon and lead deposits
Old 05-06-2006, 09:11 PM   #3
shelby987
shelby987's Avatar
Re: stuck valve?
I would assume the best way to diagnose either of those issues would be to pull the head?
Is it really likely that I melted a valve or cracked a piston ring?
Old 05-06-2006, 10:01 PM   #4
qksilver
Re: stuck valve?
If a chunk of carbon came off, oh yes..........
diamonds are really compressed carbon
qksilver is offline   Reply With Quote
Old 05-07-2006, 12:18 AM   #5
jhow66
jhow66's Avatar
Re: stuck valve?
Piece of carbon came loose. Remove plugs and crank engine over. It will blow loose stuff out plug hole. (if you are lucky). Or a loose piece of carbon is holding valve off seat. No way you melted a piston. Have steamed cleaned piston tops many times with water dribbled from a bottle with engine running at a fast idle.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
