Old 05-06-2006, 05:54 PM   #1
dmigura
loose power on high end
This may not be the right forum to post this question, but this is where i always go. I have a 1970 4x4 with 71,000 miles original motor. I have had about a year and it looses power at about 65mph especially when I am going into the wind. the motor also starts to clatter a little. I replaced fuel filter, checked timing, and run medium otcane fuel and still the problem exist. Any ideas on what it might be.
dmigura is offline   Reply With Quote
Old 05-08-2006, 10:55 AM   #2
1969K10
1969K10's Avatar
Re: loose power on high end
Have you looked into your vacuum advance for your timing? Is it hooked up? If so, pull some vacuum on it to make sure it's holding vacuum... Just grasping at straws here...
1969K10 is offline   Reply With Quote
Old 05-08-2006, 07:04 PM   #3
Paul M
Junior Member
Paul M's Avatar
yea..hook a timing light up..and rev it a bit in and you should see the timing advance to like almost 40....if not,check vacuum diaphram and also check weights in the dist itself. if those are working,id do a compression check of all cylinders...and lastly, with truck off,make sure carb is opening fully,by taking air cleaner off and looking down into carb.butterfly has to be straight up and down,then check the linkage to be sure its opening correctly...ok shot my wad..hope you fix it
Paul M is offline   Reply With Quote
Old 06-06-2006, 11:05 AM   #4
wibilly
wibilly's Avatar
it may also be a worn cam i had a 64 seemed to run great till i got in high gear then no power pulled valve covers and found valvs to be oppening very little
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-06-2006, 12:13 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
or weak valve springs too.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 06-07-2006, 06:12 AM   #6
What size tires and what gears.There`s more to it,but this info would help get a baseline on the truck.In other words,could make your problem more pronounced.
Old 06-07-2006, 01:17 PM   #7
dmigura
I am running 33s with stock gears not sure what they are it is a 70 half ton with a 4spd. I put a quadrajet from a 1980 ranch truck that I have just to see if that maid a difference, and it seems to be running better. I think something might of been wrong w/ the old carb.
Old 06-28-2006, 01:02 PM   #8
220mph
Speed Limits...yeh right
220mph's Avatar
I had the same problem. It wound up being the distributor shaft bushing was worn so the timing was going out under load.
1972 3/4 ton 4x4 LONG BED
1940 Chevy Pickup
1970 El Camino Pro Street 496BB w/NOS
220mph is offline   Reply With Quote
