![]() Join Date: Feb 2003
tilt difference
whats the difference between the van tilt and the truck tilt? mine seems too close to me, is the difference in the length? thanx,dave
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
Re: tilt difference
Apparently several inchs different in length as well as location of neutral safety switch and shape of the turn signal plug in thinger.
Lots of great info here. |
Re: tilt difference
If I remember correctly the neutral safety switch on the van tilt is not in the same place. Its too far down the column and interferes with the brake pedal arm. So the switch has to be moved up the column and the collapsible steering arm on van tilt has to be shortened by about 4".
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. Last edited by Southpa; 05-06-2006 at 09:13 PM. |
Re: tilt difference
kool....thanx....
