05-07-2006, 01:09 AM | #1 |
67' question
I guess its actually a 70 question. Ive got a 67 longbed with a 70' 350 in it. It has a four speed with granny gear. Im looking for an automatic and would really like to fit a Th400. Does anyone know if it can be directly bolted? Or any that can? Thnx
05-07-2006, 01:31 AM | #2 |
10/30/19
Re: 67' question
Absolutely,a 400 turbo hydromatic will bolt up to your 350 no matter what year it is.A th350 will also do the job.Some say that the th350 shifts harder.
Fight the good fight, finish the race, keep the faith |
05-07-2006, 06:27 AM | #3 |
Re: 67' question
I think you`ll need an automatic croos-member.The 4wds swap right in,that`s all I`ve done.
05-07-2006, 06:41 AM | #4 |
Re: 67' question
I would like your sm420 4 speed if it is good condition. Shipping would be high most likely. zip 75022 I can pick it up at a truck terminal including ups or fedex.
05-07-2006, 07:02 AM | #5 |
Re: 67' question
going to a 400 turbo will require the drive shaft to be shortened. A 350 turbo with a short shaft tail, is a direct bolt in.
1997 GMC Sierra Ext 1965 Mustang |
05-07-2006, 11:53 AM | #6 |
Re: 67' question
A chevy 400 will bolt, there are B/O/P patterns also
05-07-2006, 12:59 PM | #7 |
Re: 67' question
I think you will have to remove the front manual crossmember for clearance. The SM420 may have a driveshaft yoke that the driveshaft bolts to similar to the rear end. If that is the case, driveshaft mods will be needed. Your current shaft likely has a slip joint near the hanger bearing, and that wont work with and auto setup. Might be cheaper to find the front half or whole shaft from a truck with whichever trans you use, there should be plenty still around.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-07-2006, 03:52 PM | #8 |
its all about the +6 inches
Re: 67' question
this would be an easy swap being that the truck could come with a TH400 or a TH350 in 70 hooked to that engine.
You'll need; Tranny probbably drive shaft mods/replacement yoke tranny cooler lines tranny cooler (real big one if you don't have one in the rad) a way to shift it (aftermarket shifter on the floor or a new column, good time to get a van tilt unit) auto tranny cross member tranny mount Shift linkages (n/a if going with an aftermarket shifter) *MIGHT* need a longer speedo cable |
