05-07-2006, 11:13 AM | #1 |
gas smell
i have a 71 c10 that i use as a daily driver. It smells very strong of gas when driven. How can i fix this?
05-07-2006, 11:36 AM | #2 |
Rottenwood Garage Member
Re: gas smell
Check the gasket arround the filler neck on the outside of the truck...replace if cracked. Check O ring gasket under sending unit...replace if cracked/worn. Check rubber parts of fuel lines on tank end and replace if cracked. Inspect for pin holes on fuel tank...JB-Weld if leaking. Inspect engine compartment for fuel leaks. Carb. area, fuel lines.
05-07-2006, 03:58 PM | #3 |
its all about the +6 inches
Re: gas smell
Also, if there is an exhaust leak under/before the cab... that can be very misleading.
The 2 main areas on the in cab tank that I have found for leakage ar the filler neck (commonly the joint from filler to tank is cracked from ppl leaning on the pump nozzle when pumping) and the rubber o ring on the sending unit piece. Slide the seat forward and look for spots int he dust that look like it's had fuel rinsing it off. |
05-07-2006, 10:19 PM | #4 |
Re: gas smell
I had my 71 parked in the garage for 4 days while on vacation and when I got back the garage smelled of strong gas fumes. One of the rubber lines to the fuel pump started leaking... There are many different points for a possible leak... check everything. BTW, Welcome to the board!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland www.YouTube.com/user/593Films - Watch My Videos! 1977 Silverado K10 2014 Dodge Durango (Wife-mobile) 2008 Dodge Ram Lone Star Edition (Daily driver) |
05-07-2006, 10:57 PM | #5 |
Re: gas smell
Even with a new gas cap I don't fill much above 3/4 tank because it can still leak when the gas slops around in there. Might help.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-07-2006, 11:40 PM | #6 |
Turbo Guy
Re: gas smell
Just my 2 cents but, When I took the cab off mine to send to paint I found a return line for the fuel pump has a factory splice that is conected by a chunk of rubber hose, it was really hard to see and I did not know it was there before. The rubber hose was so bad it was a hiccup away from leaking fuel in excess(was already seeping). I mention this because it is very close to my header and it wouldn't take much to light on fire from there. Just my 2 cents ,Dave
05-08-2006, 08:13 AM | #7 |
Re: gas smell
My 71 had gas tank leak (owned this thing back in HS). About got sick from the fumes. Replaced with junkyard tank. Pretty easy.
But rust / dirt in the junkyard tank then clogged up my fuel filter, cause stalling at highway speeds. Replaced fuel filter every oil change for a while until all the gunk was out of the tank.
'72 Chevy K-20 Crate 350, SM465, 4.10's |
