Old 05-07-2006, 08:32 PM   #1
shelby987
shelby987's Avatar
High temp RTV silicone removal?
I bought some headers for my project, but the previous owner put them on his truck with high temp rtv silicone, and I can't seem to get any of it off the mating surfaces of the flanges, and I am pretty sure this would present a problem for getting a proper seal. Does anyone have any tips for getting this stuff off?
I have tried to use a razor blade, but that doesn't seem to work all that well.
Any ideas?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 05-07-2006, 08:41 PM   #2
QKENUF4U
QKENUF4U's Avatar
Re: High temp RTV silicone removal?
wire wheel
QKENUF4U is offline   Reply With Quote
Old 05-07-2006, 09:46 PM   #3
13lazer
13lazers' blazers
13lazer's Avatar
yeah wire wheel mounted on yer drill. stuff rags anywhere you don't want debris
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 05-07-2006, 10:33 PM   #4
cduster
Mineral spirits, or carb cleaner works.
Dan
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 05-07-2006, 10:38 PM   #5
shelby987
shelby987's Avatar
damn, wished there was something easier.....
Tried carb cleaner, no good....tried brake cleaner......stilll no go.
Should I worry about scuffing the surfaces of the flanges, or as long as they are somewhat flat and clean, I am ok?
Old 05-07-2006, 10:45 PM   #6
QKENUF4U
QKENUF4U's Avatar
wire wheel shouldnt hurt the surface any
Old 05-07-2006, 11:32 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
I put a wire cup brush in the drill. You can also use Permatex gasket remover, I've used it on other silicones.
There is a reason for the rtv, but it wasn't applied right, at least in my book. The six has a problem with leaks around the manifolds. What I do is use the ultra copper rtv, but I put it between the gasket and the manifolds. A thin bead, all the way around. Keep it off the head, makes cleanup easier. After applying and before installing the manifolds, let it cure for a few minutes. Then put on the manifolds, and don't over-tighten the bolts. Let the thing sit a full day before starting so the rtv cures. Trim off the excess with a knife or razor.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-08-2006, 05:04 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Permatex makes an RTV -specific stripper. The more serious auto parts stores have it, but not the bubblegum chains [Checker, Auto Zone, etc.]
