Old 05-07-2006, 10:59 PM   #1
Myself
Water in oil, please help,need opinions
Finally got everything put back on my wife's '68 Chevy. New everything! Got it fired up right away, adjusted timing, then set the idle up to 2000 RPM to break in the cam. Oil pressure great, sounded great, running cool. Checking for leaks after about 6 min. then checked the oil. MILKSHAKE!!! I took the intake back off and there are a couple spots that look like they could have been the problem. After only the initial 6 min. runtime there was 3-4 qts water in the oil. No steam out the exhaust at all. Do you think I'll be safe with intake gaskets? Do you think the bearings got hurt? Thanks in advance.
Myself is offline   Reply With Quote
Old 05-08-2006, 08:28 AM   #2
truckdude239
truckdude239's Avatar
Re: Water in oil, please help,need opinions
drain the oil try changeing the gaskets and try again if its not the intake gaskets you are l;ooking at blown head gaskets for a cracked block but as long as you dont have the knocking sound of death just change the oil might have to change it 2 or 3 times to get everything out of it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-08-2006, 08:42 AM   #3
68jimmy
68jimmy's Avatar
I had a similar experience after firing up my motorm turned out to be a crack in one of the valve seats... I flushed the motor several times with fresh oil and filter so far so good.
good luck.
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 05-08-2006, 09:41 AM   #4
Myself
Yeah, I'm thinking that much water that fast has to be the intake gaskets.
Old 05-08-2006, 05:56 PM   #5
chooch406
Once you find the water leak I'd be checkin the bearings.Antifreeze is very abrasive. 6 minutes of liquid sandpaper should be plenty of time to wipe the bearings.
Mike
68 Gmc 1/2 ton pickup
66 Malibu
87 GN
85 Sub parting out
03 Yukon
chooch406 is offline   Reply With Quote
Old 05-09-2006, 12:45 AM   #6
roger0080
When I put my intake on my brand spank'n new GM crate engine, I was filling the radiator up with antifreeze/water and and I hear water splashing down onto the ground. Turns out my intake manifold gasket slipped down in the rear right side, not sealing the water holes. I drained the oil and changed the filter, and redid the intake. I'ld check your intake.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 05-09-2006, 03:12 AM   #7
72armyswbtruck
72armyswbtruck's Avatar
Good Luck with your endeavors
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 05-09-2006, 10:18 AM   #8
Myself
I put on new intake gaskets and put it back together last night. If it's not raining when I get home I'll start 'er up and see what happens.
Old 05-10-2006, 06:28 AM   #9
dwaite72lnghrn
Everytime I used the front and rear galley seal I had leaks. I now use RTV on the front and back(wait 12hours at least to set) and leave the oil pan drain out, Fill the rad and watch for water to come out the drain. Then put drain in and fill with oil and start it.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
