Old 05-08-2006, 10:52 PM   #1
wibilly
wibilly's Avatar
speedy sleve
went to napa today for a speedy sleve for my pinion yoke on a eaton ho52 and was quoted $42 and some change. anybody have a better source? i was gonna check with MN bearing but they were closed by time i got there
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 05-09-2006, 12:25 AM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: speedy sleve
Just curious but what the heck is a speedy sleve? and where/what does it do or is it located at?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 05-09-2006, 02:04 AM   #3
jimfulco
Re: speedy sleve
It's a thin metal sleeve that is tapped over a used balancer hub or pinion yoke that has a groove where the seal rubbed on it for a long time. It restores a seal-worthy surface to an expensive part that otherwise would have to be replaced.
jimfulco is offline   Reply With Quote
Old 05-09-2006, 03:14 AM   #4
72armyswbtruck
Re: speedy sleve
Cool, so it's basically a sleeve or insert, Thanks for the info, BTW Good Luck on your fix
Old 05-09-2006, 08:01 AM   #5
mrein3
mrein3's Avatar
Re: speedy sleve
I have never heard it called a "speedy sleeve" but I have installed many of them on the harmonic balancer on many small block Chevys.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 05-09-2006, 05:39 PM   #6
powell72
powell72's Avatar
Re: speedy sleve
Speedy sleeves aren't cheap, but $42 does sound a little high.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 05-09-2006, 07:11 PM   #7
wibilly
wibilly's Avatar
Re: speedy sleve
mrein3 what do you call them ? i beleave speedy sleave is a manufacturer kinda like cresent for an ajustable wrench, or chanel locks for water pump pliers
Old 05-09-2006, 07:17 PM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: speedy sleve
Another name is redi-sleeve. And that price is the going rate, I was quoted $38 2 years ago. I would guess they quit making them, since the last year for the ho52 was 72.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-09-2006, 07:28 PM   #9
Sweet72
Sweet72's Avatar
Re: speedy sleve
I think speedi sleeve is a chicago rawhide brand. Never used one, but I've heard they'll restore the surface and get rid of those pesky drips. They say that you install using loc tite to hold it in place.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 05-09-2006, 10:01 PM   #10
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
Re: speedy sleve
Here at Advance where I work, there called Redi sleeve's. I'll check on a price from us tommorrow when I work.
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 05-10-2006, 07:43 AM   #11
mrein3
mrein3's Avatar
Re: speedy sleve
To be honest, the last time I bought one I went to a parts counter where a knowledgable guy I know works. I asked for,
"one of those deals you whack over the hub of the engine balancer so my oil seal won't leak"
He knew what I was talking about and went in the back and grabbed me one.
Oh, and I like to stick the part in the freezer for a while before I whack it on there.
I've never put one on a rear end however. I've only used them on the front of a small block Chevy engine.
'72 Malibu hard top
Center City, MN
Old 05-10-2006, 06:43 PM   #12
1969 GMC
1969 GMC's Avatar
Re: speedy sleve
I'm pretty sure they just manufacture those by size, not specific application, and then catalog them. They are pretty costly for any big size. My dad had to put one on the spindle of a 14 bolt for a 1 ton at work, and it was huge. Don't know how much it cost, though.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-10-2006, 09:12 PM   #13
wibilly
wibilly's Avatar
Re: speedy sleve
size rather than application is why i thought i'd try the bearing house before i shelled out the money at napa where they list everything by application
Old 05-10-2006, 10:51 PM   #14
ClemsonChevy
Re: speedy sleve
Advance carries it by the brand BCA/National. Our price was 45.88 for the H052.
95 2500 350 w/ 3.73
