05-08-2006, 11:55 PM | #1 |
Blue 67
Having hard time to take rear seal off
It's me again with my brake story!. How do you take this thing off? There is no place to take hammer and push it out. They told me before snip it but how? just cut it? Sorry to be so amateur.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
05-09-2006, 04:06 AM | #2 |
Re: Having hard time to take rear seal off
what rear seal are you trying to remove and from what? ae you talking axel seal? and what rear?
common sense isn't so common anymore |
05-09-2006, 10:38 AM | #3 |
Blue 67
yes, I am sorry I should have been more specific. The seal in the rear hub which prevent the rear diif fluid to get to rear brakes. I don't know what exactly it's name is.
05-09-2006, 11:04 AM | #4 |
I'm still not completely sure of what you're trying to do, but it sounds like you're trying to get an axle seal out from the end of the axle (behind a tire). It should come out with a small screwdrive CAREFULLY. get in behind the edge, and pry it out a little at a time working your way around the seal.
05-09-2006, 11:10 AM | #5 |
It's a catastrophic success.
You will have to pull the axles first,
http://www.autozone.com/servlet/UiBr...3d80112bcb.jsp |
05-09-2006, 11:19 AM | #6 |
Blue 67
Ok, I think we are talking about the same thing. Again, sorry to be so lame. After you take the tire off and remove 8 bolts and take the shaft out, you pull the hub off of the brake assembly, In this assembly from outside to inside we have two bearing and a seal behind the second bearing. I am talking about this seal. It is seated very firmly I try to use screw driver it didn't work althought I didn't use too uch force fearing I am gona damage the edges. I thought there might be some kind of puller or something for this purpose.
05-09-2006, 12:57 PM | #7 |
Your doing a 3/4 ton, just pry the seal out or take a piece of broom handle stick down through the hub and hit it with a hammer it is just pressed in.
05-09-2006, 07:28 PM | #8 |
if you remove it plan on replacing it. i just bought new ones for my eaton ho52 at o'riley's. i think they were $7.99 each
05-09-2006, 07:31 PM | #9 |
stick the end of the axle in the housing and "pop" it out with the end of the axle. Buy new ones, they are not worth saving.
05-10-2006, 12:37 AM | #10 |
Blue 67
Ok, I guess when you start you mechanic experience at age of 36 with no previous experience this happens! Would you explain on below picture at what dorection and on what you hit to get this s#$ out!
05-10-2006, 12:17 PM | #11 |
Push the lower bearing and seal in the direction of the brake surface. Note when putting back, that the flat side of the seal faces out
05-10-2006, 12:20 PM | #12 |
Blue 67
Thanks. I just wanted to be sure that I have to hit the bearing.
