Oilfield Trash
??? For Anyone Using A 90's Booster/Master Cylinder
What kind of mods did you have to make on your truck to make it work, can u use the stock pedal bracket and pedal? How about the prop valve use the new one or the old?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
Questionable
Re: ??? For Anyone Using A 90's Booster/Master Cylinder
*bump*
just b/c i'm curious also.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
More Cowbell....
I am curious also. It sure would look nice to have the booster bolted directly to the firewall....*BUMP* & TTT for ya'
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
chevy truck fan
blue85,
i just put a '92 sub. mc & booster on my '72 chevy 2wd p/u. the mods weren't too bad. i had to modify the booster bracket at the bottom right side for steering clearance issue. then the rod to the pedal on the inside needed to be switched out with the one from the suburban it is a little short but it works, still feels real solid. if i remember right i had to put another nut at the end of the rod. that is all i remember doing to get the booster & mc to actually fit on the firewall & connect up. it wasn't too bad it should be pretty easy for the most of you, i am not a fab wiz so i try to keep things simple. good luck!!! rodstored-72 |
Post Whore
You got any pics of the setup? I am still trying to decide the best way to go on brakes.
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons ![]() |
how did you have to modify the booster bracket? cutting? bending?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
Oilfield Trash
ttt
chevy truck fan
71swbchevy,
i had to cut out a little square section of the lower right side of the bracket to clear the steer. column bracket to the firewall. i just used my handy dandy dremel with a cutoff wheel. if i remember right i think it was about 1" or so of the corner. other then what was listed before that was it. i would take a pic or two, but i don't know if i can post them muchless how... if i get some help i will be glad to take a few & get them to you... rodstored-72 |
Just A Tool Hand
that would be nice to see, being that I'm going to have a bb455 and there isn't muck room for that 6' ext. hahaha
:hit: |
#10 | |
Post Whore
We don't have to have pictures if you don't have the time, I think I can get it with just the write-up. Thanks for all the information you have already provided us with.
Active Member
![]() Join Date: May 2005
I ordered a smaller diameter dual diaphram setup (including master cylinder, prop valve for disk/drum) From NO LIMIT ENGINEERING (909)386 7637 for $361 and that was 5 years ago. Great setup, bolts right in stock location (1972 1/2 ton). At the time they didnt have the little swivel/heim joint piece to bolt it to the pedal. So after completely smoking an old drill, I got a new hole in the pedal to put the bolt through. I found out later, from some random person, that it is a booster from an astro van. I havent confirmed that. I can get pictures later, working at the moment.
Jason ________ MODELING Last edited by Jayss109; 04-27-2011 at 11:39 PM. |
![]() Join Date: Feb 2004
not quite a 90 but something to look at
http://67-72chevytrucks.com/vboard/s...d.php?t=183125 may interfere with column shifting |
