Old 05-09-2006, 12:05 AM   #1
CATMAN
Question 350?
I have to plead ignorence. I recently purchased a 1980 4x4, 1/2 ton running parts truck, that someone has converted from an automatic to a standard. My question is; in my 75, with a 350, there is a boss on the right head behind the alternator with the serial number, plus the exhaust manifolds go over the plugs, with the plug wires running under the manifolds. In the parts truck, there is no boss on the head behind the alternator, and the exhaust manifolds run under the plugs, against the block, while the plug wires run over the valve covers. I'm sure this is still a 350, just newer? Thanks!
CATMAN is offline   Reply With Quote
Old 05-09-2006, 01:05 AM   #2
Russell
Professional Grade
Russell's Avatar
Re: 350?
I've seen 350s with both style of exhaust manifold, so you can't really identify an engine with it. My general experience has been that the over the plug type manifolds usually are found on 305s though.
That said, my 80 has over the plug type manifolds that originally came off an 83 1 ton 350 engine
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-09-2006, 10:13 AM   #3
hotrodhomi
hotrodhomi's Avatar
Re: 350?
Run the numbers on the block
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 05-09-2006, 12:20 PM   #4
82c10
needin' money
Re: 350?
i agree
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 05-09-2006, 11:10 PM   #5
CATMAN
Re: 350?
I'll run the numbers this weekend. Thanks!
