C10 Club Tennessee
Power Steering Gear Box Options?
see ten and I were talking this weekend about his quick ratio steering box he has on his truck and he mentioned that he thought the same thing could be achieved by some newer model gear boxes. Anybody have any idea which ones? or are we wrong?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
![]() ![]() Join Date: Jul 2002
Re: Power Steering Gear Box Options?
I know 1980 - 87 full size truck boxes are, I think it might even include any of the 73-87 boxes from the fullsize trucks.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 05-09-2006 at 01:05 PM. |
C10 Club Tennessee
Anybodyelse want to back up Bill's comment before I go to the junkyard?
I'm interested in this too as I am in the process of wanting to install a power gear-box and a quicker ratio box that is a BOLT UP would be great. So far all I hear is that the fittings are metric o-ring vs. the old type.
Anybody have a years recommendation? We can always have hoses made with the proper fittings to match old-style pump to new-style boxes. |
its all about the +6 inches
73 - 87 boxes work, and they are variable rate boxes, but as far as I know, there are no quick ratio boxes from another aplication that'll work.
I am a Referee of life.
OK I'll jump in with both feet.I would like Rack and pinion but I haven't seen any except the new one out that uses a thinner aftermarket crossmember.When looking at the original crossmember I thought the lower control arm mounts would make an Ideal point to put a bracket to locate said Rack.It would probably require more than just those 2 mounting points.Has anyone seen one or heard of a "bolt-in" type system to do this.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
some one came on here about 3 years ago asking about interest, he was looking into making a bolt in R&P unit... no clue what ever happened with the idea.
C10 Club Tennessee
Andy-Explain Variable Rate Box?
Mine is leaking at where the steering shaft goes into the box. I actually ahve a later model front end on my truck so somebody has already changed over the power steering pump. Hell, I might already have a 73-87 gear box.
#9 | |
The LuvShack Garage
![]() *Taken from the PO's list of New parts AGR STEERING BOX (VARIABLE RATIO)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 05-12-2006 at 05:04 PM. |
It's hard to explain... think, slow steering at center... and faster steeering past a 1/4 turn from center. You really wouldn't notice it onless you pay real close attention... or go from one to another.
#11 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
good point
#13 | |
The LuvShack Garage
hardly ever notice the differance, but you have 20's, so maybe
#14 |
I was reading about guys with first gen camaros using 3rd gen camaro quick ratio boxes, but have no idea if they'll just bolt in.
I'm going to be replacing mine soon since it leaks. |
#15 |
Camaro boxes are inside the frame, trucks are outside.
Wouldn't work. |
#16 |
Fabricate till you "puke"
I have an 84 Burb box on my longhorn.....love it. It took 1 full turn out of the lock to lock,as compaired to the old 69 box. The meteric fittings were an easy "hassel", just used the hoses & fitting (rear of the pump) from the Burb. I really like the feel of the steering, & will say that that old 133" longhorn is easier to park than the kids Ferd ranger! Im not sure why, but it takes some doing to turn that Ferd around? I am 2wd, lowered, with 15"(basically stock height tires for a 1/2 ton), & will say the box was a nice addition to my old truck, & noticable......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#17 |
C10 Club Tennessee
I just would like to know when I go get the 73-87 gear box, am I upgrading or am I getting the same? I guess I won't know until I do it. Either way I don't have a problem with my steering just don't like the small leak. Figured if there was an upgrade on a newer style gear box would do it while the old one is out.
#18 |
Yellow 69 - If your steering is now 4+ turns lock to lock you probably have the original box. The newer and variable ratio box will be in the 3+ lock to lock area. Lock to lock means how many turns hard left all the way to hard right.
Hope this helps a little bit - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
#19 |
71 rustless in texas
Was surfing and came across this. For you guys that REALLY want rack and pinion steering check out this link.
http://www.jimmeyerracing.com/ifs7.html
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" ![]() 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
#20 | |
The LuvShack Garage
#21 |
If you have a small leak, put you some trans-x in your pump. It stopped the leak on my pump. It's worth a shot.
#22 | |
![]() John |
