Old 05-09-2006, 12:51 PM   #1
Daubs
Daubs's Avatar
What to do with my old 350?
I have the new 350 crate motor in the garage. Cannot get my $100 core back because the block is cracked.
What to do with the old engine? Save the heads / cam-lifters / bottom end? Or just toss on scrap heap?
Thanks. Daubs
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 05-09-2006, 01:01 PM   #2
Re: What to do with my old 350?
They make good table stands
I'm probably going to turn mmine into scrap whenever I get unlazy enough to haul the load of scrap metal I have to the recycler.
Old 05-09-2006, 05:30 PM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
Turn it into a smoker
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-09-2006, 05:32 PM   #4
Psycho71
Psycho71's Avatar
Me, I would save everything that is in rebuildable shape and make trotline weights out of the rest of it. A scrap yard might work if you don't fish.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 05-09-2006, 05:54 PM   #5
TugOwar
had a friend back home with a 70'ish chevy wrecker. the 350 in it had froze and cracked and been welded. he had been running the motror i know 5 five years and it was a good motor.
i guess the point is, cracked doesnt automatically mean its scrap.
TugOwar is offline   Reply With Quote
Old 05-09-2006, 06:20 PM   #6
Blue85
Oilfield Trash
Blue85's Avatar
check the casting numbers on the heads, probably should save them
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 05-09-2006, 10:31 PM   #7
mblackburnjr
collector of vintage rust
mblackburnjr's Avatar
Where is it cracked at?....It may be able to be welded back by someone who can weld cast.........probably not a good idea if its near the rotating assy.
mblackburnjr is offline   Reply With Quote
