Old 05-09-2006, 01:12 PM   #1
Troy 82
Brake light
On my 82 the brake light stays on. It started the other day. The first time it did it I turned the truck off & on & the light went out. Now the brake light stays on. Pressing the E brake make the light brighter but releasing the brake doesn't make the light go out. I looked in my shop manual & couldn't find anything about it. Thanks!
Troy
1982 Silverado
Troy 82 is offline   Reply With Quote
Old 05-09-2006, 01:43 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Brake light
Here is the thing, the emergency brake pedal is not going completely back to the position to depress the brake light switch to OFF. reach under the truck and pull on the E brake cables after they have been released and the light will go out. The problem is that the switch either needs to be adjusted or the E brake cables need adjusting to make the pedal return to full UP position. I usually just stick my foot under the truck and push on the cables when this issue shows up, to get by until I have time to adjust the cables.
piecesparts is offline   Reply With Quote
