hahaha
How do you tell a BB truck with the motor and trans out?
How can I tell if the truck came out with a BB or not? The truck I'm looking at now has the motor out and the owner says it had the BB but how do I tell for sure? Thanks for the help Joker69
69lwb, 29 A coupe hotrod, 55 chevy hardtop, |
Strongman Garage
![]() Join Date: Apr 2000
check the glovebox door and look on the options sheet
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
The truck should also have a big transmission hump in the floor.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
by the 402 badges...lol
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Frame mounts for big block should be different from small block mounts.
Heavier springs on front end for 1/2 ton trucks. There is a rumor going around that sometimes there is a build sheet hidden within the seat if it still has the factory seat. You might want to confirm this. Still the easiest way to confirm is the Glove box option sheet but it could have been with a big block truck to increase the value. See if the numbers on the Glove box sheet match the frame and body id tags. Good Luck
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
BB ??
Check to see if power steering pump reservoir is maybe still mounted to the drivers fender? / or there should at least be mounting holes for one. This assumes it had PS , but any BB trucks I owned did.
#7 | |
"Ochre Ogre"
Other subtle clues would be a remote reservoir for the power steering pump mounted to the drivers fender or a heat shield mounted to the angled part of the floor right below the heater core. It should be approximately 4"x12" and bolts on from inside the cab. If the fan shroud is around, it doesn't look anything like a small block 2wd or 4wd. That's all I can think of that hasn't been covered already.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
hahaha
Thanks for the info I'll be checking it all out in the AM. Joker69
