Finished Sound-Deading
This thing better be quiet. I put two layers of damping material on the floorboard and rear panel. A layer on the inside of the door skins and on the firewall and all up under the dash when I redid the whole interior. It made a big difference in the door. Just closing the door you get a solid sound.
Just wondering something....I have Headman longtube elite headers. Even ater all these layers and the carpet I am getting readings (from a laser thermometer) of about 100-110 degrees on the floor board, is that about right? Do long tubes make that much heat....I hate to see what the temp was without anything but jude mat and carpet. |
Oilfield Trash
Re: Finished Sound-Deading
What kind of sound deadener is that?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
Are you taking the temp readings off the sound matting or the bare floor? I've found that laser temp guns do not work well on a reflective surface. Will not give a correct temp.
1997 GMC Sierra Ext 1965 Mustang |
Half Brown Bread half RAAMmat BXT. I was taking a reading off the reflective surface. But I did take the truck for a drive and I did not have seats in them so I sat directly on the carpet, and you could definately feel the heat after awhile.
sound deadening does very little in the way of thermal insulating ...
Licensed to Thrill!
YOU SPENT SOME CASH!!!
That stuff is expensive though, no joke. I'd at least like to do my doors. I am thinking of using this in place of my missing A/C box on my firewall inside to get noise damper and heat control...then just some of the other in the doors. My carpet does a fairly good job. I think I got into the ACC before they went to pot or something. |
Looks GOOOOOD!!!!!! Great Job! I did the same to mine, but used DynaMat Extreme.
I used Peel n Seal for Lowes for $45 (3 rolls), and was AMAZED.
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
#9 | |
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
chevy truck fan
moto,
i am very interested in what you used. could you please tell a little more about its purpose??? i may go to lowe's & check it out as well... thanks! rodstored-72 |
Formula, don't mean to hi jack thread..3 rolls did 1 layer. When I get some buckets I may do another layer because it was so cheap. I can notice a heat reduction from engine and the exhaust note from inside has demished significantly. Very Pleased.
#12 | |
http://www.lowes.com/lowes/lkn?actio...17-81326-PS625 its main purpose is to go on roofs to seal vents and what not.
#13 |
Commander Taco Bello
does it smell like asphalt in your truck?
#14 |
