81 SWB blown sbc project
Haven't posted on here in a long time so here is where i am now. I am currently working on my 81 gmc swb that I have had for 6 years now. Last year I hit my goal of 11's on stock suspension (11.98 @112mph) and decided that its time to build the truck how I want. I parted out the engine and am starting from scratch. Tore down in January and hopefully it will be driving by August.
Specs of new setup: 383 cid with afr 227 comp heads, .650 mechanical roller camshaft, enderle bug catcher mechanical injection hat, 6-71 blower, and little magneto. I am retaining stock suspension with the hope of running mid 10's then I will change that Here is how it sat before tear down ![]() Here is how it sits now ![]() The rest of the suspension parts are drying now and I should have it back to rolling chassis by the end of the weekend. Firewall is getting shaved and 90 degree mount master cylinder will be inside the cab. Can't wait to get it on the road.
11.98 @112mph Stock suspension and little tires. |
needin' money
Re: 81 SWB blown sbc project
i like it before, sent you a pm.
SWB Stands for Short Wide Bed |
tonights progress
progress of tonight. When i started tonight the rearend was in and that was it. Front springs are much easier with help. But i made due
![]() Me, jack, 2x4, and 320lbs of sand ![]() Then end of the night this is where I was. ![]() Yeah it needs dusted pretty bad. I think tomorrow when I ROLL it out of the garage I wash her. My connecting rods showed up today so monday when i get my bearings I will assemble the shortblock, check my clearances (assuming my camshaft is in by then), then take it back apart for balancing. The end is near.......
11.98 @112mph Stock suspension and little tires. Last edited by 81shavedtrk; 05-14-2006 at 01:00 AM. |
Just curious...what powered it to go 11's?
#5 | |
I am hoping for low 10's with the new setup. We shall see......
11.98 @112mph Stock suspension and little tires. Last edited by 81shavedtrk; 05-14-2006 at 05:39 PM. |
She sits on all 4 tires for the first time in 4 months. Now I can move on to other parts of this disaster or a project.
most of the brake lines have been ran and now I am waiting on my camshaft to show up so I can finish mocking up the bottom end.
![]() Join Date: Apr 2005
I guess you didn't have access to a spring compressor? You did a great job making due with the jack, 2x4, sand, etc.
#9 | |
