05-10-2006, 12:14 AM | #1 |
Just A Tool Hand
the first mock up........
and it looks tight. the brake booster doesn't look like it well fit alomg with alot other things. but
I guess it be worse,RIGHT!!!
:hit: |
05-10-2006, 09:41 PM | #2 |
Re: the first mock up........
what is that a buick?
common sense isn't so common anymore |
05-10-2006, 10:04 PM | #3 |
Just A Tool Hand
Ya, it is a 455
:hit: |
05-10-2006, 10:38 PM | #4 |
hey, what side is the starter on on a buick?
05-10-2006, 10:42 PM | #5 |
It will fit, just make sure that you get an engine oil filter relocation kit. I once owned a 70 that had a 455 in it and the PO cut the frame rails instead of relocating the oil filter. Good Luck
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
05-10-2006, 10:49 PM | #6 |
Just A Tool Hand
where can you get a relocator kit at? and were do you move it to, does it just point the filter down?
The sttarter is on the passenger side.
:hit: |
05-10-2006, 10:50 PM | #7 |
Just A Tool Hand
also did it have a high or low hump in the cab?
:hit: |
05-10-2006, 10:53 PM | #8 |
I just bought onr from summit racing filter relocator and oil cooler for 80 bucks .
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 |
05-10-2006, 10:56 PM | #9 |
Just A Tool Hand
was that for a buick 455?
:hit: |
05-11-2006, 12:52 AM | #10 |
MEMBER
The type I have used had A block where the filter normally goes with two hoses coming away from it so you can relocate it wherever it fits best and you just cut the length of the hoses accordingly...Single oil remote..Easy install and even easier oil changes later on. Just check for leaks....
86 sub 4wd, 1 ton, duallie, big block th475 72 c10 short fleet, pro street 72 K/5 blazer,2x4 almost stock 72 3/4 ton sub 4x4 61 morris minor pickup, chevy 4.3 v6 03 escalade, 24" momo's wifes 96 2wd 2door tahoe 67 2wd suburban 72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo. |
05-11-2006, 09:01 AM | #11 |
Looking good!
Did you have any luck finding motor mounts? Hope it all fits, because when I'm ready to put my 455 in I will know how to call. |
05-11-2006, 11:17 PM | #12 |
Just A Tool Hand
Ya it is coming as fast as work and the wife lets it come. The motor mount brackets are from a 73-87 chevy, it doesn't mater there are all the same. When I get them and get them install there will be pics! The motor mounts them selfs not sure how to weasel that one yet but that day will come. might be able to find some or have a mach. shop build them, we'll see!!!
:hit: |
05-11-2006, 11:22 PM | #13 |
its all about the +6 inches
lookin good man... gotta love the mixed breed swaps. Shows originality.
I always say, GM made plenty of good truck engines...they just enver installed any of them in trucks. |
05-11-2006, 11:27 PM | #14 |
Just A Tool Hand
They probaly knew Guys like us would do it anyway! They didn't want to take our hobby (LIFE) away!!!!!!!!!
:hit: |
