Old 05-10-2006, 04:33 PM   #1
68racer
Yeah baby!
68racer's Avatar
Hooker Super Comps
I'm looking at Hooker Super Comps for a big block 2wd. How far do they hang down from the chassis? Ground clearance is my only worry. But any other advice is welcome. I'm looking at the two inch primaries as I think the 502 needs a bigger pipe.
Neil.
11.37 @116
68racer is offline   Reply With Quote
Old 05-10-2006, 06:14 PM   #2
71Dragtruck
71Dragtruck's Avatar
Re: Hooker Super Comps
They hang low being equal length primaries, but are built for the best performance, not clearance. I've had the 1-7/8" and the 2" shown and they are the same.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 05-10-2006, 08:36 PM   #3
Bowtie468
Bowtie468's Avatar
Here's a pic of my Hooker Comps. 2" primary 3 1/2" collector. These are Chevelle headers, part # 2455
Pics a lil blurry, but you can get a general idea.
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 05-11-2006, 12:14 PM   #4
68racer
Yeah baby!
68racer's Avatar
Wow guys that is great information, why can't you get this info on manufacturer's sites? Time to get the tape measure out and see what I can get away with. I just put a 502/502 in my 3800lb truck, the 60' is good at 1.67 but it is not pulling at the top end as it is only doing 105mph. We are going to try some more timing, have changed the coil and think that bigger primaries may help. Actually cutting the roof off would help but I don't want to go that far!
Neil.
11.37 @116
Old 05-11-2006, 12:15 PM   #5
68racer
Yeah baby!
68racer's Avatar
Forgot, the et is not good at 12.2, I need those11's!
11.37 @116
Old 05-11-2006, 12:17 PM   #6
71Dragtruck
Sounds like your running out of carb? What are you running?
Sponsored by:
Hard Candy Customs
Old 05-11-2006, 04:02 PM   #7
68racer
Yeah baby!
68racer's Avatar
850 double pumper, half inch fuel line splitting to two 3/8 lines at the regulator, blue top pump holds 7psi at the carb all the way. I don't think we had enough timing at 34 degrees, and are going to put in 36 next time. Old coil had a resistance of 4.1 ohm, new one is 4.7 ( both Blaster 2).
Open to suggestions!
Neil.
11.37 @116
Old 05-11-2006, 05:51 PM   #8
71Dragtruck
Neil.
34 isn't that much, try even 38. I take it your running mechanical secondaries vac are good on the street but not as good for racing. Also may sound stupid, but have someone check you carb to make sure your getting full opening on both when you put it to the floor. Other than that how do the plugs look after a wide open run.
Sponsored by:
Hard Candy Customs
Old 05-12-2006, 02:27 PM   #9
68racer
Yeah baby!
68racer's Avatar
Yes mechanical secondaries, I think that it is the timing, yes getting full throttle. How much does running a truck hurt your terminal speed in comparison to a car of the same power? I mean the poor aerodynamics.
Neil.
11.37 @116
Old 05-12-2006, 02:30 PM   #10
68racer
Yeah baby!
68racer's Avatar
How much horsepower would the tuned length headers make over the Comps shown? both with two inch primaries. I do like that ground clearance and it is street/strip, they would be cheaper too.
Neil.
11.37 @116
