Old 05-10-2006, 11:30 PM   #1
Daubs
Daubs's Avatar
Edelbrock Alum. intake painted(!?)
PO installed Edelbrock performer dual p. intake...and then painted it chevy orange. I'm putting in new crate 350 and wanted the aluminum intake look. So I powerwashed the intake and got 90% of paint off, then took to my engine builder for bead blasting the last stubborn paint and some grime.
Engine guy said the intake had been sandblasted before it was painted and that the blasting basically ruined the look. I said go ahead and blast it and we will see...only $40.
Will I need to coat the bare aluminum? Clear coat? Or should I hit it with Aluminum paint? Or just leave it as is?
Suggestions?
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 05-10-2006, 11:35 PM   #2
william 70 c/20
Re: Edelbrock Alum. intake painted(!?)
now that it's been blasted twice you need to spray it with orange paint...J/K i know Eastwood makes some great aluminum finishing products..
william 70 c/20 is offline   Reply With Quote
Old 05-10-2006, 11:40 PM   #3
franks72
Junior Member
franks72's Avatar
If the glass bead in the beader is new the intake will come out looking new ..If the bead in the machine is old it will look dull
franks72 is offline   Reply With Quote
Old 05-11-2006, 07:18 AM   #4
Raw is fine.That`s what the new ones are.I think they get bead-blasted after casting as well.If I did anything,I`d get it ceramic coated.
Old 05-11-2006, 07:29 AM   #5
70c10
67-72 Addict!
70c10's Avatar
I agree with the ceramic coating idea. That would look good.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-11-2006, 08:53 AM   #6
wolfthing2000
Paint it or coat it! Aluminum does not do well under the hood, unless you clean every other day. They all look greyish black given enough time if left bare.
wolfthing2000 is offline   Reply With Quote
Old 05-11-2006, 09:33 AM   #7
68Stepbed
68Stepbed's Avatar
I painted mine with engine paint. The color is Cast Coat Aluminum. I bought it at Advanced Auto. Looks real close to cast color, but it's alot easier to clean It's made by Dupli-Color.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-11-2006, 10:38 AM   #8
Daubs
Daubs's Avatar
I was thinking about painting it aluminum color. Not really interested in ceramic coating...kind of like polishing a turd (my truck).
Old 05-11-2006, 10:41 AM   #9
Billla
Billla's Avatar
If it was sandblasted with aluminum oxide or something other than glass bead, it won't hold up bare. I've tried a number of diffferent products on bare aluminum that's been abused, including Eastwood's clearcoat without what I would consider great success. I think once it's been blasted, it needs to be coated - paint, powdercoat, ceramic - whatever floats your boat
Billla is offline   Reply With Quote
Old 05-11-2006, 10:45 AM   #10
Putter
More Cowbell....
Putter's Avatar
Why not powder coat it in the aluminum color? I have some powder that is called "Chrome", but it comes out the color of polished aluminum (like wheels) and is slick as glass. I have done older (classic) aluminum valve covers with it and they look great. I might do my intake next time I unassemble the engine.
Just a thought.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-12-2006, 12:25 AM   #11
kelsfine69
18 Till I Die
kelsfine69's Avatar
I took mine out of the box and mixed up some car clearcoat with a little bit of pearl in it for sparkle. Then sprayed it. Cant complain been on ther 10 years now, holds up realy well. Ask a bodyshop for a quote. They all have leftover cleacoat laying around after they fix a repair.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-12-2006, 03:48 AM   #12
72armyswbtruck
72armyswbtruck's Avatar
Hey, that clear coat idea looks pretty good, better then just plain stock edelbrock.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 05-12-2006, 07:52 AM   #13
wibilly
wibilly's Avatar
i've used just clear it turns them kinda grey i've also used aluminum paint and then clear. this method looks much brighter and more the coler of a new intake but much easeir to keep clean
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 05-12-2006, 03:01 PM   #14
Daubs
Daubs's Avatar
Haven't seen the intake just yet, still at bead blasting. I'm planning to paint it with "cast-coat Aluminum" paint, then possibly clear coat it. I'll post before and after pictures when I can.
Old 05-14-2006, 09:54 AM   #15
gfcsteve
powder coat it, it will look great and hold up. the powder is chemical resistant,gas doesn't seem to bother it its easy to clean and you can get it any color you want. ceramic coating s are designed for high temp applications your intake is not going to get hot enough to hurt the powder, and powder is cheaper than ceramic
steve
wwww.gforcecoatings.com
gfcsteve is offline   Reply With Quote
