Junior Member
Anyone replace the shifter seal ina t350 tranny?
mine seems to be leaking a bit to much for my liking there.any insights as to procedures and problems associated with it would be appreciated.i included a pic of the shifter and you can see the fluid..thx for your help..paul
Firefighter
Re: Anyone replace the shifter seal ina t350 tranny?
It takes a National seal #8792s. And KD Tools makes a very handy tool to remove and install it #2393.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Junior Member
ahh thx for the quick reply...couple questions before i dig into this...do i need to drop the pan?..or is it removable from outside?...thx again paul
tcoop68
No,you won't have to remove your pan,just take off your linkage I got my tool from mac it will screw right into the old seal and you will be able to pull the old seal right out.I use a 1/2" socket to drive the new one in so you wont damage the new one.Good luck. tcoop68
![]() Join Date: Jul 2004
A small thin and sharp screwdriver can be tapped through the metal part of the seal and pryed out that way, just be sure not to score either the case or the shaft, or it will still leak.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
![]() Join Date: Feb 2004
Man I love this site, more and more knowledge everday, better watch out or my Head will explode!!!
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Designated A-hole!
I bought the tool, but still wound up dropping the pan and driving it out from the backside. Wasn't that big a deal with the help of some guys on here.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#8 | |
Licensed to Thrill!
Man - I was fretting that my seal was leaking, and wondering what to do. NOW I KNOW! WOOHOO! Thanks for posting this. |
take a small sheetmetal screw & drive it into the metal part of the seal-stay away from the sides. then pry seal out using screwdriver under the head of the screw-on some stubborn or large seals you may have to screw both sides. brian
Watch out for your cornhole !
![]() Join Date: Jun 2003
The KD tool is under 20 bucks, and that's both remover and installer in one package. Personally, I wouldn't risk a scratch or gouge on the shaft by using another method to save the 20 bucks. If you do scratch the shaft, it will leak from now on, no matter whether seal is new or not.
#11 | |
Licensed to Thrill!
http://www.thetoolwarehouse.net/shop/KD-2393.html http://search.cartserver.com/search/...ords=KD%202393 |
