Old 05-11-2006, 06:28 PM   #1
truckdude239
truckdude239's Avatar
carrier bearings
okay does any one make a good soild carrier bearing? when i replaced my transmission in octocber i replaced the u joints and carrier bearing well when i was under the truck today i noticed it starting to break this one i got from orielys it has life time free replace ment but i dont want to keep replacing them? any ideas?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-11-2006, 06:36 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: carrier bearings
If yours is the teardrop style good luck i finally got tired of snapping them and put a one piece drive shaft in my 68 short fleet
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-11-2006, 06:44 PM   #3
farside847
farside847's Avatar
I saw one once on here for like $400 that was supposed to be the end-all thing. Too much money for me...
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 05-11-2006, 07:41 PM   #4
neonlarry
neonlarry's Avatar
This is what I use:
http://www.iedls.com/bearings.html
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-11-2006, 08:13 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That's one way to avoid fixing the real problem.
Old 05-11-2006, 09:46 PM   #6
truckdude239
it looks liike this lastone that was on it looked it it only alot older
David fuller
2000 Tahoe 5.3l 378
Old 05-12-2006, 12:13 AM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
Originally Posted by neonlarry
Oh man I gotta get one of those. That is sweet
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-12-2006, 12:51 AM   #8
Jemost 72
Southern Bowties
Jemost 72's Avatar
It appears the replacement carrier bearings for these trucks are junk. When I replaced mine, I bought it from NAPA, thinking they would have the best. As I installed it, I was tightening the last nut on the rear u-joint...and the carrier bearing just fell down. Upon inspection, it appeared the spot welds were so small it just broke loose. Put a good weld on it and re-installed it, its held strong ever since.
1972 Cheyenne 350/350
Jemost 72 is offline   Reply With Quote
Old 05-12-2006, 02:12 AM   #9
4x4Poet
I've just begun getting into my C10 burb. I think the problem with center support bearings wearing out at the rubber surround has more to do with the lack of a slip joint in the rear half of the two-piece driveshaft. When the suspension cycles up and down, the rubber surround has to flex to allow the entire driveshaft to move fore and aft with the movement allowed at the splined yoke in the transmission. I guess I'm only speaking of a two-piece driveshaft behind a TH350 in a half ton truck with a 12-bolt.
Even Inland Empire Driveline Service recommends a twopiece, splined rear half driveshaft. In fact, I'm pretty sure that the poly carrier bearings won't flex as much as rubber ones, so the suspension cycling may stress the poly or the bracket surrounding the poly. Something has to absorb or allow a two-piece driveshaft with no slip joint aft of the carrier bearing to move fore and aft under suspension cycling.
At the bottom of this iedls page, they recommend a two-piece slip jointed DS when using their 7075 poly bearing. There's a lack of clarity in the wording of that paragraph. I need to call them, myself.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-12-2006, 03:40 AM   #10
72armyswbtruck
72armyswbtruck's Avatar
I agree, I need to give these guys a call and check on pricing. I need to replace my carrier and u-joints.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 05-12-2006, 07:49 AM   #11
truckdude239
do you think it would help to have my driveshaft rebalanced?
David fuller
2000 Tahoe 5.3l 378
Old 05-12-2006, 09:45 AM   #12
JustLiveIt
JustLiveIt's Avatar
Had my drive shaft rebalanced and a new carrier bearing pressed on. Will update progress after I install it.
Jemost 72: My old carrier bearing failed at the spot welds too. The new one is spot welded but also is welded all around the mouting plate too. Hopefully that works. If not I'll go with a one piece from Inland Empire since they are a short drive from me.
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts!
JustLiveIt is offline   Reply With Quote
Old 05-12-2006, 09:58 AM   #13
truckdude239
mine is breaking around the bolt holes on top
David fuller
2000 Tahoe 5.3l 378
Old 05-12-2006, 02:33 PM   #14
Ackattack
Ackattack's Avatar
I used to have problems with mine. The Bracket that the carrier bearing bolted to broke and was bent. Might want to inspect that.
I made a new bracket out of some square tubing and haven't had problems since.
Ackattack is offline   Reply With Quote
Old 05-14-2006, 03:39 AM   #15
4x4Poet
I'm looking into having my local driveshaft shop add a slip yoke to the rear half of my two-piece carrier bearing driveshaft. Should be cheaper than a whole new driveshaft like IEDLS sells. I might still go poly carrier bearing for an install and forget combo.
Also, it probably doesn't help that some of us run sagging springs with cheap, worn out shocks. That must increase driveshaft fore and aft movement at the transmission end splined yoke and therefore the carrier bearing also.
<-------one of the *some*
Old 05-15-2006, 03:31 PM   #16
JustLiveIt
JustLiveIt's Avatar
Got the shaft in and everything works well. Don't know how long it will all last but we'll see. If it breaks again I'm going 1 piece shaft with the ECE extreme drop cross member. I think my angles are less than ideal with the 6" drop, 2 piece shaft, and stock cross member.
Old 05-15-2006, 05:52 PM   #17
neonlarry
neonlarry's Avatar
One thing to note with any drop of 4" or more the rearend will need to be recentered (as in an adjustable panhard bar).
Old 05-15-2006, 06:19 PM   #18
JustLiveIt
JustLiveIt's Avatar
I have the super track bar from ECE. The PO was using the stock track bar with the 6" drop for an unknown amount of miles. That may be what killed my previous bearing. I centered the rear as best I could when I installed the super track bar but I need to get it to an alignment shop for a 4 wheel alignment.
