Full Gauge Cluster Upgrade
A few months ago I tried upgrading the cluster in the '84 Suburban to a full gauge cluster from a 454 Suburban (an '88 I believe). The OE cluster in my truck is the base cluster with the idiot lights and the 454 cluster had all the gauges. I realize I'd have to change out the oil pressure sending unit but I figured it would be a direct swap. None of the gauges responded correctly and I pulled the printed circuit board off both clusters and compared them. They were completely different (wires leading to the batt light on the base cluster led to the temp gauge on the full cluster for example).
I'd like to upgrade the cluster because I plow with her but I don't know what year/engine is a direct interchange. Does anyone have a wiring diagram of the base cluster from an '84? What year did they change the cluster wiring or was the base cluster one harness and the full cluster a second harness. I did this upgrade on my '96 Beretta a few years ago and, other than the oil pressure sending unit, it was a direct swap. Thanks |
yeller
Re: Full Gauge Cluster Upgrade
Contact "crossy" and see if he can help. He is our resident factory tachometer guru.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Anything from '78 - up should work on your '84 WITH some modifications. You can't just plug it in and work.
You need to get a wiring diagram (I use Haynes) and move the pins in the cluster plug to match the printed circuit.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
