07-30-2002, 08:20 PM | #1 |
72 Cheyenne
K&N air flow top
Anybody using one of these? Notice any diference? Just want to know if it's worth the $45
07-30-2002, 08:49 PM | #2 |
A buddy has one...
A friend of mine has both the top filter and the 14" element and it sure looks sweet...LOL. He says it feels better. In reality you may get a little better mileage, and ya know more air means more power. But you not going to feel a huge difference with 12-15 hp.
In the long term I think the setup is worth it, being that it is reusable/ cleanable...
68 SWB The Surgeon General doesn't say anything about smoking a Ford!!! Would rather be ran over repeatedly by a Chevy than drive a Ford!!! Paralyzed from the neck up and confined to a hat! Kathleen, Georgia USA |
07-30-2002, 08:55 PM | #3 |
YEP -- I'VE GOT ONE ON MY BB. YOU WON'T NOTICE THE DIFFERENCE LIKE A 400 HP N2O KIT, BUT, MORE AIR IS DEFINATLY BETTER. (YA BETTER ADD A LITTLE TO THAT $45 FIGURE THOUGH)
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
07-30-2002, 09:47 PM | #4 |
Currently Blazerless
I have one on my 383, I was using it along with an edalbrock air-gap and the old truck woundnt hardly even run in the winter, I finally switched intakes and I still remove the K-N in the late fall and put on my old stock air cleaner.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
07-30-2002, 10:16 PM | #5 |
I'VE NEVER EXPERIANCED A PROBLEM OF HAVING TOO MUCH COLD AIR, OF COARSE I LIVE IN NEVADA AT ABOUT 5000 FEET ELEVATION & IT SELDOM GETS TO 10 BELOW EITHER, BUT A REGULAR AIR CLEANER IS NOT GOING TO HEAT UP THE AIR, NO MATTER HOW COLD IT IS.
07-30-2002, 11:09 PM | #6 |
72 Cheyenne
Pep Boys sells just the top which is all I need for $45 I'll try it out. Thanks guys.
07-31-2002, 01:15 PM | #7 |
i thought about getting one when i get a cowl induction hood, but i was thinking 'will it suck water with a cowl induction hood and one of those tops, the hoods have a piece welded in so you're not sucking everything in but i'm just concerned about the water issue,
68 short step, 406/700r4, 9" w/discs. |
