05-12-2006, 02:18 AM | #1 |
How do I get this lower
I need some help and input. This is my 71 Cheyenne Short box. I have bagged the front and rear. I also have 2.5" drop spindles on the front. This a coil spring truck with the trailing arms. I put a set of new snubbers in just incase I lose a bag. This way I can drive it on to a trailer. The rear end is sitting very close to the underneath of the bed.. The front tires sit to close the inner fender wells. I want to go lower but do not want to cut up the truck. Any ideas???? If I have someone Z the frame do I have to lose the inner fenders and cut the bed???
Thanks |
05-12-2006, 02:41 PM | #2 |
Re: How do I get this lower
Do you have a C-notch?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-12-2006, 02:58 PM | #3 |
Insert Title Here
This is more of a question than to answer you.... but do you think you would get any lower with the tubulars like these?
http://www.classicperform.com/NewPro...ionPackage.htm
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
05-12-2006, 10:21 PM | #4 |
There is only so low you can go with the inner fenders in. I had a bagged '72 with a notch and 2'' blocks and my diff was touching the bottom of the bed floor. It only sat a little lower than yours. Your truck is just too nice to cut up for the sake of another 1-2 inches.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 05-12-2006 at 10:22 PM. |
05-13-2006, 02:25 AM | #5 | |
1LoC10, I wsill call them on Monday and ask some questions on this. This is trick looking. I wonder if it works with bags? |
05-13-2006, 02:31 AM | #6 | |
The bags helped get it lower than what I had before. Thanks, |
05-13-2006, 12:59 PM | #7 |
Beautiful truck!
I am sad to tell ya no matter how much work you do and how much money you spend you can only get as low as the body lets you go. Have you thought about having some one make you custom inner fenders that allow your tires to come up more with out looking bad? Have you seen the yellow 60's burb on the forum that have notched the inner fenders to lay out on 20's? I know the fenders are different but the same idea applies. As for the back maybe you would raise your bed floor a few inches as to keep the super smooth look. I will say it probably isnt worth it after what you have into it. Sometimes you have to just say, "I will build the next project different." Keith |
05-13-2006, 02:05 PM | #8 |
Insert Title Here
for the front you can bolt in a new crossmember like this one
http://www.fatmanfab.com/06page7.htm it cost a good amount, but it should save a lot of trouble of trying to section the stock stuff, and its all bolt in
05-13-2006, 09:18 PM | #9 |
67-72 Addict!
It's tough to improve on perfection!. Your truck is incredible!!!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-13-2006, 10:42 PM | #10 |
Señor Member
Contact slammed67 on mod'd inner fenders-- he took stock ones and sectioned them up to get more clearance. On the rear, you could raise the entire bed floor. Done well, few would notice.
