Old 05-12-2006, 03:16 AM   #1
redneckdds
redneckdds's Avatar
long or short h2o pump?
which pump do I need on my crate 350? It came with a long style pump. I am putting Vintage Air in the non a/c truck and want it to go thru the passenger side... so, the alternator should go on the driver side. I am hearing differing things and need some help... thanks
'67/70 Chevy C/10
'10 2500 Crewcab Duramax 4wd
redneckdds is offline   Reply With Quote
Old 05-12-2006, 03:41 AM   #2
redneckdds
redneckdds's Avatar
Re: long or short h2o pump?
forgot to mention... its gonna use a vbelt, not a serp
'67/70 Chevy C/10
Old 05-12-2006, 04:24 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
short.
Old 05-12-2006, 05:42 AM   #4
junkyardjohn
junkyardjohn's Avatar
EITHER ONE WILL BE FINE. WHEN YOU ORDER YOUR VINTAGE AIR UNIT JUST TELL THEM WHAT YOU HAVE,"(SHORT W/P, ALT. ON THE RIGHT SIDE, ORIG. FACT. AIR OR NOT) & THEY WILL OUTFIT YOUR SETUP TO FIT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-12-2006, 11:37 AM   #5
coolair
Going with a short pump will be easier if your crate motor has a steel timing chain cover (not plastic - i.e. Ram Jet). With the short pump you can get the ac hose kit that is allready crimped - less hassle during install - just make sure you get the proper pulleys also for belt alingment.
coolair is offline   Reply With Quote
Old 05-12-2006, 01:01 PM   #6
68speedalert
Semi-Senior Member
68speedalert's Avatar
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 05-15-2006, 10:13 PM   #7
68Stepbed
68Stepbed's Avatar
Short. I went the long pump route and never could find hoses that fit right. 67-72's came with short pumps, so finding replacement parts is easier.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-15-2006, 10:54 PM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
I made the mistake of switching to a long pump. Brackets pulleys are a problem. The lower radiator hose is a whole nother issue. If I had it to do over again, I would stick with the short pump.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
