Old 05-12-2006, 01:17 PM   #1
texan1186
Under Major Construction
texan1186's Avatar
Front Airbag Problem
This past weekend i bagged the front of my 82 c10 with some drop spindles, ***************** upper bag plates and cups and firestone 2500 bags. Ive only driven it for the past two days but in that time the truck will slowly drop but the air pressure in the bags goes up. There arent any air leaks that i can find, so what is happening? am i supposed to air them out at night and inflate them in the mornings?
1982 Chevy Silverado 350/700r4
see it here
texan1186 is offline   Reply With Quote
Old 05-12-2006, 01:37 PM   #2
Mitchell_01
Re: Front Airbag Problem
sounds like your bags are breaking in
Mitchell_01 is offline   Reply With Quote
Old 05-12-2006, 02:23 PM   #3
Hart_Rod
Hart_Rod's Avatar
Also, does it sit outside? Change in air temp could be causing some it the difference also.
Rob
Hart_Rod is offline   Reply With Quote
Old 05-12-2006, 06:14 PM   #4
texan1186
texan1186's Avatar
Yea it stays outside. I was just worried something was wrong because this morning they were at 84 psi and the truck was way too low to drive. Anyways, thanks for the info.
see it here
Old 05-13-2006, 02:33 AM   #5
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
You really should of went with 2600's in the front as they take less pressure to lift.. is your gauge accurate ?? wheres the pics ?
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
