Old 07-30-2002, 09:20 PM   #1
raychevy
88 Lesabre Worse
Okay the buick got worse. I installed a new oxygen sensor because the car gave error code 13. After installing it I left the car running while I put up the tools and washed my hands. So about 5 minutes later I get in the car and its idling rough, I try to give it gas and it dies. Then it wont restart, but its trying. Whats weird is it always starts easy and runs really good, even if I drive it. Its when I stop and let it idle a bit that it seems to get hot or something and wants to quit. I tested the spark with a spark tester and its bright. I think its the fuel filter, but I dont know why it would run good when its cold or being driven. Can anyone please help me ? Ive got 1500 in this car and I need the money bad.
raychevy is offline   Reply With Quote
Old 07-30-2002, 11:33 PM   #2
toms68cst
toms68cst's Avatar
Do these things run an EGR valve? I had a kind of similar problem with my 90 Burb/350 EFI a month ago. A new EGR Valve straightend it up right away.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 07-31-2002, 06:15 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
The problem is it's not a 67-72 Chevy truck.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 07-31-2002, 08:01 AM   #4
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Yea, Could be the the fuel filter.
Also when was its last tune up?
My 92 OldsmoBuick was running crappy last week and it turned out to be wires. They were original with 150K on them.
Also sounds like it could be the MAF sensor but that should trip code 33? Thats an expensive part to just through at it.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 07-31-2002, 08:02 AM   #5
DennyB
DennyB's Avatar
Oh yea, Have the coil pack tested.
I.M.O.M,W,J&C
Patriot Guard Rider
Old 07-31-2002, 08:44 AM   #6
68 Suburban
68 Suburban's Avatar
I'm guessing your coil pack is bad. I think my father went through this problem a few times with his 92 Olds. You need to check the coil pac with an ohm meter to make sure they are with in spec. That car could have 1 of 2 coil types ranging from $45 to $80
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
