better than stock front suspension?
okay, so i'm getting ready to sell the reliable, great-running, noproblems excab dodge in order to fund my LS1 swap
![]() while the engine's out, i want to re-work the front suspension. it's bone stock, '72 with disk brakes, etc. when i drive it now, it feels...unsteady. tends to walk a little, horrible cornering, and although i haven't inspected it, i would guess that there's quite a lot of wear on the a-arms and "Jesus" bolts, maybe even "wallered out" a bit. how should i go about rebuilding this front end so that it feels more solid/modern, while still maintaining stock ride height. i don't want to slam or even lower it, but most of the components i find do just that. i'd love to find aftermarket stuff, maybe tubular? that will be stronger/more responsive than stock. oh, and i don't want to spend a TON of cash, either. does anyone have any suggestions? it seems i've only found info on lowered kits. thanks!
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
Gone Fishing
Re: better than stock front suspension?
I would just rebuild what you have back to stock specs and add a sway bar, or go with a 73 and later front susp. They ride a little smoother and don't have the steel bushing control arm shafts like the 72 does.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Fabricate till you "puke"
The steel bushings may be a little stiff, but they dont flex, & are good for d@mn near 1/4 MILLION miles if you grease them! Your next best would be a 73 up with urathane bushings. On the sway bar.....73-up fits, I run a 3/4 ton bar on my longhorn(inch & a quarter) if I remember correctly. That old longhorn will sit flat as h#ll @ 70MPH in the off ramp......she drifts real sweet tho
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
