05-12-2006, 06:52 PM | #1 |
teraflex
would i encounter any problems if i put a set of terflex shackels on my lifted stepside? i do A LOT of road/interstate driving but i would love more flex. any help would be awesome!
05-12-2006, 10:37 PM | #2 |
Re: teraflex
how is the rear currently lifted? Just lift springs? How much lift do you have? A shackle flip would provide 4" of lift and give you better flex than lifted springs. If you have 6" of lift, a shackle flip and 2" springs would work better with same lift. Just an alternative idea. Shackle flips are far more common on these trucks than tera flex shackles.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
05-13-2006, 11:33 AM | #3 |
Re: teraflex
its a four inch suspension 2 inch body. lift blocks in the rear......shackel flip....do they sell a kit for that?
05-15-2006, 01:08 PM | #4 |
K5Camper
Re: teraflex
Yes they make shackle flip kits. Off Road design makes them and so does Sky.
OR- You can convert your existing rear spring hangers by removing the shackle, cutting open a hole and reinstalling the shackle through the hole. (brace up the hanger though) Another cheap option is to get the front spring hanger from the rear spring of a 3/4 ton 73-87 truck and install it in place of the stock rear hanger. (requires drilling out of stock rivets on both hangers) Teraflex revolver shackles were not originally setup for our trucks. They were designed for Jeeps. Some say the revolver shackles give spooky handling on/off road when the shackles unload when you don't want them too. Do some searching on other sites like www.CK5.com where this question comes up every month or so and you will see a lot of detail on them. Personally, a flipped shackle on our trucks does a better job without the spookyness. I've had mine flipped for over a year now and driven on and off road without any problems. Off road it rides soft and flexes soooo much better. Go with a shackle flip.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
05-15-2006, 03:29 PM | #5 |
Re: teraflex
I have the taraflex revolver shackels on my jeep and it made it way to hard to drive on the road. they are very unstable for street driving. Another problem is when you are offroad they will let you get so twisted up that you can break allot of different things. I will be pulling them off my jeep soon and trashing them
05-16-2006, 10:43 AM | #6 |
Re: teraflex
awesome....thanx for the advice everyone! one more question tho. if i have a four inch lift with blocks, i can install the shackel flip, take out the blocks, and be left with the same ride height i was at before?
05-16-2006, 02:22 PM | #7 |
Re: teraflex
Tonka, yes that is the idea.. Blocks=BAD! shackle flip wont cause quite as much axle wrap...
